EGR Delete opinions? - Page 7 - Chevy and GMC Duramax Diesel Forum
Old 12-09-2012, 10:33 AM   eBay Motors  #61 (permalink)
DaveB's Avatar
Originally Posted by duramaxchris06 View Post
Is upgrading the y-bridge a necessity? Or is the stock one fine with an egr delete?
In most cases stock is fine. If you're going to pull the turbo out I would go ahead and do the bridge though to make sure you never have issues with it coming apart.
DaveB is offline   Reply With Quote
Old 12-09-2012, 11:54 AM   eBay Motors  #62 (permalink)
StealthBoogie's Avatar
Originally Posted by juddski88 View Post
GMT-900 hoods are taller, his is a GMT-800. (i should clarify the OP has a chevy, so ot should fit regardless, but gmt 800 gmc hoods will not clear sdp egr delete pipes, unless they have changed in 6 months) Did you batmowheel give you more HP and tq in your ideal range of use? Better track times?
Yes it does add HP but not much. It spools hell of alot faster then stock and lowers egt's. I dont take my truck to the track so i cant give you track times. Mackyoudip did see an improvment in track times but he also did other mods the same time he installed it as did I. Plus it sounds sick
My LMM Build Thread
08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake
Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves.....
StealthBoogie is offline   Reply With Quote
Old 12-09-2012, 12:54 PM   eBay Motors  #63 (permalink)
DIESEL ADDICT
06BLACKSTALLION's Avatar
Well i plan on doin a turbo and injectors after my tranny so I am not goin to bother with the batmowheel. If i take out my turbo I want to be puttin a new one in. And hearing you guys talk upgrading the y bridge should be done if turbo is in future?
2006 Chevy 2500HD LBZ
EFI Live w/ DSP5 tuned by Todd Ely of PDS..5" Straight Piped MBRP exhaust w/ 7" tip..MBRP down pipe..AFE intake..AFE bladerunner..Autometer Cobalt Gauges..Spyder CCFL Halos.Debadged..Rerouted..Ready Lift leveling kit..18" Metal Mulisha Rims runnin w/ 325/60/R18 Pro Comp Xtreme All Terrains
Upcoming mods: Pro Fab manifolds,up pipes and EGR delete, built trans
06BLACKSTALLION is offline   Reply With Quote
Old 12-10-2012, 09:23 AM   eBay Motors  #64 (permalink)
DaveB's Avatar
The reason most say to do the y-bridge with turbo change is because it will make it much easier to get to with the turbo out of the way.
Old 12-10-2012, 01:05 PM   eBay Motors  #65 (permalink)
DIESEL ADDICT
Oh I see. Well I dont think it will hurt to do a y bridge now and it will be done when i get the turbo in a couple months.
Old 12-11-2012, 06:47 AM   eBay Motors  #66 (permalink)
juddski88's Avatar
It really all depends what turbo you want, how much you have to spend, and your overall goals for the truck guys....you are all making such generalized statements about these mods, it's like all i see in these threads anymore is regurgitation from salespeople's mouths. I don't push parts, i install them, test them, and break them.
2001 ECSB Silverado HD SS- "Sore Subject"-LBZ block, DTS-ported LLY heads and Exergy Injectors, DTS cam, controlled by LB7 electronics, Big Dipper trans parts, raybestos clutches, built my me w/DPC custom converter, HTT Custom turbo, Pro-Fab long tube headers, custom wiring, custom exhaust, Aluminum Traction Bars, custom suspension, Setrab Fuel Cooler and 15gal fuel cell, CryO2, Custom Nitrous, Custom CM Roll Cage built by Dominator Race Fab and Diesel Performance, Custom Paint by Full Tilt Auto Body and Keith Brick Designs, custom H2's and some other stuff I am probably leaving out. Thanks to BT Dieselworks, DTS, HTT, Blackout Diesel Performance, Todd Greene, Evan, Kyle and all of my friends and family.
Freedom Diesel
juddski88 is offline   Reply With Quote
Old 12-11-2012, 03:29 PM   eBay Motors  #67 (permalink)
DaveB's Avatar
I agree! I'm saying to consider the y-bridge because I have the SDP delete and still blew my bridge apart. Now I'll be getting a full 3" setup and won't have to worry about it again. It does depend on how far and what you are going to do with the truck. Had I of known, I would have spent the extra few hundred and got the hi-flow bridge in the first place.
07 CCSB 4X4 LBZ: Danville Billet 4094 & 45% Nozzles, DSP5 by Mark at Danville, BT Dieselworks Lockup Box, Romeo Fab Up-Pipes, Downpipe, & 3" Y-Bridge, Banks Hotside/PPE Boot, BD Manifold, Rail Shimmed, PCV Reroute, MBRP 4", S&B Intake, Airdog 2 165, Autometer Factory Match Boost/Pyro, Suncoast GMax 6-3/Precision ML built by Riley Gullett, MA Pump Rub & TC Brace & Big Hog Customs Trans Cooler Lines.
Cognito UCA's & Braces, Bilstein 5100's, Rare Parts HD Tie Rods, Line X Xtra, 6K HID Lows and Fogs, Smoked Headlights.
Old 12-11-2012, 05:13 PM   eBay Motors  #68 (permalink)
DIESEL ADDICT
Like I said gettin a bigger turbo most likely 68mm and injectors so might as well do y bridge when egr stuff is out.I posted this to get opinions and I got alot of good ones so thanks guys
Old 12-11-2012, 05:20 PM   eBay Motors  #69 (permalink)
juddski88's Avatar
I would wait to do it when you pull the turbo if you are bent on it. Doing it with the turbo in place takes twice as long.
Freedom Diesel
Old 12-12-2012, 09:26 AM   eBay Motors  #70 (permalink)
DIESEL ADDICT
Oh ok that makes sense I dont wanna struggle. Tim do you do any EFI live tuning?
