had a few questions about my lbz and what i was going to do - Chevy and GMC Duramax Diesel Forum
Old 12-16-2012, 07:55 AM   eBay Motors  #1 (permalink)
shotcaller660's Avatar
im thinking about doing a egr delete who has done this and any pictures to follow. as far as cutting your pipe and welding it shut also i need pictures...
the next thing was i am going to take my fuel rail fittings out and drill them to a 3/32 ??? any opinions
Josh-2006 lbz ccLb 4x4 @ 8080 lbs
Performance:diamond eye 5 inch, efi by rob,3 inch dp,Bd manifold,s&b,pvc,afe mp-plugged,air dog ll,edge cts,3 inch boost tube,ppe race valve,alligator trans lines,trans go,pump rub fix
Interior:
weathertechmats,clarion dvd head unit,12"subs,kenwood speakers
Exterior:tint,black lowpro toolbox,halo projector's,5000k hid,moog idler/pitt,rancho shocks,backup camera,cognito 7-9,35s,bmf novas,trac bars,iron bull bumpers,piaa lights
shotcaller660 is offline   Reply With Quote
Old 12-16-2012, 08:12 AM   eBay Motors  #2 (permalink)
boostnlb7's Avatar
ive never dealt with an egr before so i cant help there.. i have heard of guys buying the fuel reil fitting kit so there is no drilling involved, but also i cant get into details on that because i havent done it.. but ppe seems to be a popular brand for the fuel rail fitting
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 12-16-2012, 08:25 AM   eBay Motors  #3 (permalink)
gmctruck44's Avatar
If you are going to cut your up pipe to remove the egr it best to remove it and cut it flush. I would suggest that you buy a LB7 up pipe. And forget welding anything that can leak. I have removed and drilled my rail fitting it is very easy and I made mine larger than 3/32 but I don't remember how large. I also shimmed my relief at the same time with stainless steel washers from the hardware store. I have photos from when I did the fitting an relief valve I will post them later.
2007 GMC Seirra 2500, Reg. Cab Long Bed
EFI LIVE, Diamond Eye Duals, Fass lift pump, Transgo JR, Shimmed Relief valve and Ported Fittings
18" XD Hoss Wheels, 285-65-18 NITTO Trail Grapplers
2007.5 GMC Seirra 3500HD CCLB DRW SLT
stock
1994 4x4 Chevy S10
350 small block
fuel injected
http://www.dmaxstore.com/
gmctruck44 is offline   Reply With Quote
Old 12-16-2012, 08:34 AM   eBay Motors  #4 (permalink)
SST 1953's Avatar
Put in a block off plate, so much easier and the same results. Are you getting a CEL for fuel, is that why your going to drill your rail fitting?
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline   Reply With Quote
Old 12-16-2012, 08:50 AM   eBay Motors  #5 (permalink)
gmctruck44's Avatar
Even easier than the block plate is to just unplug your egr valve. That's all I have done and as long as your egr cooler is not leaking it is not a problem. But if you want to do a full delete than go with the LB7 up pipe.
stock
1994 4x4 Chevy S10
350 small block
fuel injected
Old 12-16-2012, 08:55 AM   eBay Motors  #6 (permalink)
yeah on my big tune i get a check engine light. for low fuel system pressure so i want to dril them out vs buying them at 40 dollars a piece
Interior:
Old 12-16-2012, 08:56 AM   eBay Motors  #7 (permalink)
where do u get a lb7 up pipe ?? i dont wanna pay full price for one
Interior:
Old 12-16-2012, 10:16 AM   eBay Motors  #8 (permalink)
gmctruck44's Avatar
A lot of vendors on here can hook you up with a pipe Maybe one will chime in.
stock
1994 4x4 Chevy S10
350 small block
fuel injected
Old 12-16-2012, 10:23 AM   eBay Motors  #9 (permalink)
Longbeds FTW
DMAXchris's Avatar
Just buy a Federal LB7 up pipe.
Those fittings aren't gonna solve your problem. What's the code?
06 Dmax/Allison EC/LB 4x4
Built Motor/Trans • Bullseye s375 • Stock CP3 • Built by Blackout Performance • 11.76@115
DMAXchris is offline   Reply With Quote
Old 12-16-2012, 10:43 AM   eBay Motors  #10 (permalink)
gmctruck44's Avatar
^ Agreed it may help alittle but if you are getting codes it's not likely going to help thoughs. When was the last time you changed the fuel filter?
stock
1994 4x4 Chevy S10
350 small block
fuel injected
