new here please help, truck wont start! - Chevy and GMC Duramax Diesel Forum
Old 01-25-2013, 09:45 PM   eBay Motors  #1 (permalink)
Hi, I have an 06 GMC 2500 hd with the Lbz duramax and an edge cts programer, I went to change the level back to 1 and it said error please disconnect from obdII sensor so edge can reboot, and I did and waited about 5 min and plugged it in and it said the same thing, the truck won't even try to turn over and edge is closed till Monday and I need to get back to Ohio by Monday morning I need help ASAP thanks
pmoorton is offline   Reply With Quote
Old 01-26-2013, 01:42 AM   eBay Motors  #2 (permalink)
Hang it!...Fire!
TDIpowered's Avatar
Update it on the internet and then try again
Max - 07 LBZ ECLB LOWERED!
Old 01-26-2013, 04:02 AM   eBay Motors  #3 (permalink)
I can't update because the software saya truck needs to be stock first and I can't get it back to stock because it won't let me use the programer
Old 01-29-2013, 07:33 PM   eBay Motors  #4 (permalink)
Super Moderator
jc1843's Avatar
Moved to LBZ performance for more help
