FASS DDRP on a LBZ Duramax - Chevy and GMC Duramax Diesel Forum
Old 04-18-2013, 07:18 PM   eBay Motors  #1 (permalink)
ccrum's Avatar
I was recently given a FASS DDRP and decided to put on my duramax. I was told I only needed to change out springs to lower to 10 psi. I went to install the DDRP and couldnt find the spring with the other installation accessories. I made the mistake and decided to install it anyway, until I could get the new spring. The fuel line measured at a constant 18psi. I recently found out that the higher pressure will damage my injection pump. I have only been running at a higher psi for about 100 miles and will be installing the new spring tomorrow. My question is, should I be worried that I have already done damage to my CP3 injection pump?
ccrum is offline   Reply With Quote Quick reply to this message
Old 04-18-2013, 07:24 PM   eBay Motors  #2 (permalink)
SST 1953's Avatar
Your probably just fine. Someone trying to make you a dodge boy? Smoke tunes and a dodge lift pump, please don't drive with your mirrors pulled out and a "C" in the rear window.
2007 CCSB LBZ.
EFI live DSP 5 by Rob @ ATP
EGR blocked, PVC reroute
AirDog II 165
TransGo Jr/pump rub mod
Firestone bags
4" MBRP
Edge Insite CTS w/ backcam
Cognito W/Bilsteins
69 Camaro S/ST-S/Gas
SST 1953 is offline   Reply With Quote Quick reply to this message
Old 04-19-2013, 07:25 PM   eBay Motors  #3 (permalink)
ccrum's Avatar
I only put the DDRP on because my cousin gave it to me for free and it is pretty much the same as a D-max lift pump except for the spring. Saved me $350. I dont have much against the Cummins, it just the rest of the Truck I dont like.
Old 04-29-2013, 03:20 PM   eBay Motors  #4 (permalink)
FASSAshley's Avatar
The spring doesn't come with the kits. The spring is a PS-1016 and it is $3.00. Give us a call and we can get one on its way 636-433-5410.
FASS Technical Support
866-769-3747
techsupport@fassride.com
FASSAshley is offline   Reply With Quote Quick reply to this message
Old 04-30-2013, 09:39 AM   eBay Motors  #5 (permalink)
ccrum's Avatar
Thanks ashley, I ordered the spring but lost it, just found it and installed it. I am measuring about 5 psi. I plan on stretching a the string and trying agan for 10 psi.
2007 GMC Sierra CCSB
EFI Live By Kory
EGR Delete
4" MRBR Turbo Back Exhaust
AFE stage 3 Intake
FASS D-max lift Pump
PCV reroute
3" level/lift
33.4" Hankook MTs on XD rims
Old 05-02-2013, 07:11 AM   eBay Motors  #6 (permalink)
FASSAshley's Avatar
Try stretching the spring to see if it fixes the low pressure issue. We usually like to see 8-10 psi.
866-769-3747
Old 05-10-2013, 12:58 PM   eBay Motors  #7 (permalink)
06 CCSB LBZ 6" lift on 20" MKWs, EFI Live w/DSP5 By Rob, Edge Insight for gauges, S&B intake, 3" DP & 5" Diamond Eye straight pipe exhaust
boy1525 is offline   Reply With Quote Quick reply to this message
