Old 10-31-2009, 06:13 PM   eBay Motors   #21 (permalink)
Jonsey181
Jonsey181's Avatar
It is quite a pain in the arse.... depending on what you want there are door locks to hook up some need to wired in relays or resistors, then you have your alarm that needs bypassing alot of wires to splice and connect, I would only do it if you have patience and are good with multimeters and electronics
Eric: 2005 GMC 2500HD LLY
Jonsey181 is offline   Reply With Quote
Old 10-31-2009, 06:22 PM   eBay Motors   #22 (permalink)
doyle81
doyle81's Avatar
is that true for starters only, without any alarms or key-less entry. is there any starters like this, just looking a morning thing and after work where the truck isn't locked. also i have a ton van that doesn't have power locks or an alarm.
'06 Silverado 2500HD, lbz, CCSB, greystone color, 5" Magnaflow SS turbo back, Evo race lvl 5, blocked EGR, Cooper S/T on 09 stock wheel, S/C stage V w/1056, BD manifold, PPE lift pump and race valve in the box.
doyle81 is offline   Reply With Quote
Old 10-31-2009, 06:40 PM   eBay Motors   #23 (permalink)
Jonsey181
Jonsey181's Avatar
yea even for the starter only your going to need the bypass which it can be done you just gotta have patience man
Old 10-31-2009, 07:53 PM   eBay Motors   #24 (permalink)
doyle81
doyle81's Avatar
thanks for the help
Old 11-03-2009, 04:02 PM   eBay Motors   #25 (permalink)
climber
climber's Avatar
I have an audiovox in my truck. Rate now it is not working... Dont know why and I have to take it back. I got it and one of those rim shops that was my first mistake. But I loved it when it worked, but I would want to install it myself so I could troubleshoot and know where everything is.
Dan
06 2500HD GMC LBZ, ECSB, 285 Cooper ST on 16" American Racing Wheels, Diamond Eye 4" into 6" Bullhaulers, Glow Shift A-Pillar Guages, Tuned with EFI Live.
climber is offline   Reply With Quote
Old 11-05-2009, 11:25 PM   eBay Motors   #26 (permalink)
tomale
tomale's Avatar
not to hijack but do you have to cut and splice the original harness to have remote start? I'd love to have it but you could'nt hold a gun to my head to splice the factory harness. I'll baby sit before I do that.
LBZ cclwb
quadzilla stealth 2, ppe boost controller, 4" MBRP from the DP, FPRV shim kit, transgo jr., DE downpipe, cognito tie rods
'83 K10 4speed, 14 bolt FF rear welded, 10 bolt front mini spooled, H1 double beadlock rims, 4" lift, hacked fenders.
I'm a trashtruck mechanic. if you want to know the best way to tear something up just ask me. I break stuff with the best of them.
tomale is offline   Reply With Quote
Old 11-05-2009, 11:32 PM   eBay Motors   #27 (permalink)
bnkrupt
ASE Certified PartsWhore
bnkrupt's Avatar
I have a Viper 791xv on the Lilly and Lbeeseven.... they are a little old skool (like 2004 styleee) but still wrk great. Most all the BEST remote srats are made by DEI (Clifford, Viper, Python, ect) and the 791 worst great. I have my headed seats on one of the many relay outputs so I can turn them on with the truck. It takes a couple bypass modules to work on the newer GM stuff, but the Directed stuff is top notch.
I came from 12V before I was in this business and I have installed 100's of remote starts, alarms, and key-less entry's. We did auto-page at first, and soon switched to DEI, as they are far more dependable.
It's no simple task on a D-max, but the reward is far worth the cost.
Pay some good money and get a good product.
Jess Hardessen | Husker Diesel | 402-570-1200
Blocker Plates | WIF Wrench | Fuel Filters
www.huskerdiesel.com | Email us!
Visa, MasterCard, Discover, American Express, PayPal
* GIVE US A CALL FOR THE BEST DEALS! *
bnkrupt is offline   Reply With Quote
Old 11-05-2009, 11:33 PM   eBay Motors   #28 (permalink)
Jonsey181
Jonsey181's Avatar
you have to tap into the Ignition harness of the truck... and usally the power to the brake, the Wait to start light, and depending on what you want lights door chimes... but nothing gets cut... or atleast shouldnt, you take a razor and peel back the insulation on the wire, then divide the wire and twist the other wire and shove it through, wrap it around a few times and then tape it.. There are some T-harnesses out there but I have never seen one for our model trucks, with those you unplug the ignition harness plug it into the t-harness which plugs into the auto start much easier
Old 11-05-2009, 11:46 PM   eBay Motors   #29 (permalink)
bnkrupt
bnkrupt's Avatar
scotch t-taps are MONEY when you are installing remote starts...
Old 11-06-2009, 06:30 PM   eBay Motors   #30 (permalink)
mattkramer21
Agree with bnkrupt on this one, get a viper or other DEI remotes. Most are lifetime warranty if installed by authorized dealer. I've had them on my last three vehicles and never had any problems.
2005 CCSB LT3 4X4 LLY
mattkramer21 is offline   Reply With Quote
