Old 11-09-2009, 08:51 PM   eBay Motors  #1 (permalink)
lefturn's Avatar
ppe question?
What does the ppe adjustable gear ratio actually do? Does it just re-calibrate the speedo for what gears you choose? why im asking is, if I dont "actually" re-gear the truck in the diff's but change the gear ratio of the truck with ppe will it raise the rpm's going from 3.73 to 4.10?
2007 gmc classic LBZ
6in BDS suspension lift
pro comp wheels 315 BFG mt's
35% tint
banks 4in straight pipe
ppe standard
lefturn is offline   Reply With Quote
Old 11-09-2009, 10:54 PM   eBay Motors  #2 (permalink)
Shhhh Its Hibernating
Tow Master's Avatar
Thats a good question! I never thought about that. I dont think it has anything to do with the wheels speed. Thats what the tire height is for.
Jason
So, I think I'm going to get a stack..... Stacks are cool..... No Im just getting one..... Oh.. Well just don't put it on the gay side..... Wait what??
Old 11-09-2009, 11:14 PM   eBay Motors  #3 (permalink)
smokin'LMM's Avatar
itl throw your speedo off.. thats it.
09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
smokin'LMM is offline   Reply With Quote
Old 11-10-2009, 06:51 AM   eBay Motors  #4 (permalink)
lefturn's Avatar
ok thats what i was wondering. i did change the tire height for my tires but the problem is i get better fuel mileage with my tow/haul button on because it brings the rpm crusing speed back up. for example @ 70 mph im at 1600 rpm and with tow/haul on it raises it to about 1800 rpm at 70 mph. so i was trying to see if i just change the gear ratio with the ppe form 3.73 to 4.10 it would throw my speedo off but raise the rpm's by a few hundred? Does this sound dumb?
35% tint
ppe standard
Old 11-10-2009, 07:34 AM   eBay Motors  #5 (permalink)
Kratos
DMAXchris's Avatar
The only way to change the gear ratio is to change the gears.
You are lugging the motor in 6th because of the wheels/tires. The only way to correct this without a gear change is EFILive. It could be used to raise shift points, keeping you in 5th instead of going into 6th.
06 Chevy LBZ/Allison 4x4 EFILive & DSP5, Suncoast IV w/1054, Suncoast Tcase brace, MA pump rub fix, PPE lift pump, AEM Intake, shimmed fprv, ported rail fittings, 4"-5" Grandrock/MBRP, torsion bolts removed, 4" drop shackles, stock turbo, stock wheels, Autometer GS boost/pyro, Aeroforce scangauge, PPE sleeves, Cognito pitman/idler braces, 8k HIDs, Recon LED tails & smoked 3rd brake, Pioneer DVD, 98,000 miles and counting
12.60 @ 105.41 mph
#15---Top 25 Fastest Stock Duramax's
Keystone 8 Luggers
Videos
DMAXchris is offline   Reply With Quote
Old 11-10-2009, 08:53 PM   eBay Motors  #6 (permalink)
Or you could put it in manual mode and leave it in 5th.
2007 GMC 2500 Classic SB/CC MBRP 4"
coblanchard is offline   Reply With Quote
