Old 02-21-2008, 09:40 AM   eBay Motors   #11 (permalink)
Landscapeman
Save Water, Drink Beer
Landscapeman's Avatar
With this bad mother
2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
Landscapeman is offline   Reply With Quote
Old 02-21-2008, 09:46 AM   eBay Motors   #12 (permalink)
aggar
aggar's Avatar
Originally Posted by TYREBOYZ_DEMAXIN View Post
my quesstion is how in the H#LL do you break the littel suckers(nuts)loose without making your knuckels look like the hit the washboard?on my LBZ the one came loose but the one towards the engine refuses to loosen and i'm scared of stripping it.
Need a bigger wrench!! Mine were a biatch too. I just checked them last night with a 3/8" drive flex head ratchet and a 12mm standard socket. it was just right to get in there. But i don't know if it'd be able to take them off.
On a side note. Has anyone else noticed if the plate has made your truck a little noisier? Mine is a little louder. Sounds like it is bouncing off the plate and you can really hear it in the cab. Can definitely hear the vanes changing at idle. Even cruising down the highway and letting off it can be heard until I give a little throttle and then it goes away. Any ideas??
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058(Fleece Performance), SC Case Brace, 68mm Cheetah, EFI Live, HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
2001 Ext Cab LB 2500hd Lb7. BoneStock! ( For Now)
Old 02-21-2008, 10:24 AM   eBay Motors   #13 (permalink)
Landscapeman
Ya there is a noise difference and as far as mine went I couldn't get a reg socket on the nut completely
Old 02-21-2008, 12:51 PM   eBay Motors   #14 (permalink)
minisub
minisub's Avatar
Try to get an air ratchet in there. It has worked for some...
2006 GMC LBZ D/A CC/SB
Hot J/A, 4" Silverline, TG Jr, Stuck and blocked....
1995 Tahoe 6.5TD
KD Chip and Exhaust, ISSPRO gauges, Heath FSD
minisub is offline   Reply With Quote
Old 02-22-2008, 10:30 AM   eBay Motors   #15 (permalink)
Landscapeman
Had the SES light come on about a day after installing. What about the finger stick? Any comments?
Old 02-22-2008, 10:41 AM   eBay Motors   #16 (permalink)
PedroMartinez
what does this help ? what does the egr suppose to do? sorry newbie here.
PedroMartinez is offline   Reply With Quote
Old 02-22-2008, 10:47 AM   eBay Motors   #17 (permalink)
Landscapeman
E.G.R Exhaust Gas Recirculator. Takes spent exhaust and recirculates it into the intake and thus the combustion chamber. Its a way to get lower emissions to stay state compliant. Also another way to get lower fuel millage. +0.2 mpg with block plate, every little bit counts
Old 02-22-2008, 11:55 AM   eBay Motors   #18 (permalink)
05_LLY
Gear Jammer...
05_LLY's Avatar
Finger sticks work real well they take about 1/2 hour to an hour to install depending. A guy here local to me is actually the "inventor" of the stick and makes them, for kennedy diesel. another option ia go with a different tuner with the egr delete function!
Caleb
05 D/ZF Reg. Cab
Under the knife to attach a second turbo
04.5 D/A CC/SB- SCIV w ATS 5star converter,Mike L cooler
Waiting install of GT4094R
Old 02-23-2008, 09:05 PM   eBay Motors   #19 (permalink)
pONSi
pONSi's Avatar
I tried to break the nuts free from the passenger side but ended up needing to lay on top of engine...I used a 1/4" drive rachet with a 12mm socket...Set the wrench in a position to where I could get some space and leverage...I then exerted a whole lot of energy into 12mm nuts (sounds like nothing but feels like alot) and got them to break free...Once they break free they spin off easy
'06 LBZ
18,000 miles to date
PPE hot +2 e.t (Jan 22,2008) sold on Jul 29,2008, EFILive (July 29,2008), egr block plate,pyrometer and boost gauges,Line-X bedliner, power step, matching door handles (Escalade), billet grille, clear braw to prevent rock chips, led tail lights, high intensity headlamps, two 10" subs, rockford fosgate 1000w amp for subs 5w-40 synthetic engine (Feb.17,2008), 75w-90 synthetic differentials (Feb.17, 2008), fuel additive (Feb.23, 2008)
pONSi is offline   Reply With Quote
Old 02-24-2008, 10:45 AM   eBay Motors   #20 (permalink)
trashygasman
trashygasman's Avatar
Mine came loose fairly easy, the only problem I had was getting it spread apart far enough to get the plate all the way down. And I only barely cut one of my knuckles.
+2006 White Silverado LBZ, CC/SB 4x4, PPE Standard, Autometer Phantom Boost and Pyro, MBRP 4" turbo-back w/ 5" SS tip, S&B cold air intake, EGR and turbo resonator blocked, DieselSite coolant filter, Transgo Jr. w/ Amsoil tranny fluid, Amsoil in the motor
+Lowrance XOG gps, B&W turnover ball & Tow n Stow, 265/75/16 Hankook ATM RF10's, OEM style running boards, Husky floorliners frt/rr, backup camera, LED 3rd brake light, white face dash gauges[/color]
trashygasman is offline   Reply With Quote
