| Premium Membership | |
| | | 06-07.5 LBZ & LLY Performance Parts Discussion Discussion of Performance Parts For the 06-07.5 LBZ/LLY Duramax Trucks No Advertising |  | |
04-23-2008, 08:14 PM
eBay Motors
#1 (permalink)
| | Junior Member
| Adding oil to Gas Tank Heard that with the cheap diesel there selling us these days, that adding a couple quarts of oil is better than a fuel additive plus it gets better fuel mileage. What are your thoughts? |
| Advertisement
04-23-2008, 08:54 PM
eBay Motors
#2 (permalink)
| | Junior Member
| I,ve heard of adding ATF. Not very much however, 1liter i think does a semi. |
04-23-2008, 09:03 PM
eBay Motors
#3 (permalink)
| | Super Man Moderator Points: 10,404, Level: 44 |
| The duramax injectors are extreamly sensitive. The holes that the fuel pass through are about the size of a human hair. Id say stick with injector cleaner if you want to add anything. If you read the owners manual it actually says NOT to add any additves
Alot of people who are use to the old diesels or even semi's will say that its a good thing to add oil or atf but these trucks are a whole different animal.
Heres a pic of the injector..
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
04-23-2008, 09:28 PM
eBay Motors
#4 (permalink)
| | Junior Member
| Go ahead if you dare, but the Dmax's are not designed to run dirty engine oil. Sounds like guaranteed trouble. The crankcase oil will carbon up the pistons, and may clog the injectors. If you want to run an additive (I do every other tank year round) try DieselKleen. I have heard of others running Marvels Mystery Oils or even 2 stroke oils in small qty's. |
04-25-2008, 06:52 AM
eBay Motors
#5 (permalink)
| | Senior Member
| My D-max a ran many miles on oil. The key is dont go over a 10% blend. With the new fuel it will thin out and be a great for the btu. In my mind dont add atf, I cant tell you how much inj I have had to replace cause people ran atf at every oil change.
__________________ Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd Omaha Truck and Trailer offering Woodworth custom build trailers.
My iron is yellow |
04-25-2008, 06:59 AM
eBay Motors
#6 (permalink)
| | Save Water, Drink Beer
| Get some Power Service and you'll wont have to worry. Good Luck
__________________ 2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel. |
04-25-2008, 07:11 AM
eBay Motors
#7 (permalink)
| | ATS Tech Support
| Like i've said before if you are set on using oil in your tank, put in a bit of two stroke oil. Its made to burn so chances of messing something up with two stroke oil is not as likely as it would be if you were using ATF (alot thicker than two stroke). Plus if you happen to get dipped with the ATF in your tank, then you can get a pretty good fine (PER GALLON). Diesels are not made to run with oil in the fuel so you will be taking a gamble with a $40,000 piece of machinery
__________________ 2003 GMC Sierra LB7 ATS *EXTREME* Transmission, ATS Aurora 4000, 4" downpipe to a 5" Single Stack, ATS Epower Programmer, Custom 4" Intake with AFE Filter, ATS Billet Tie Rod Sleeves, FASS 150/150 www.atsdiesel.com 866-230-4092 |
04-27-2008, 02:38 PM
eBay Motors
#8 (permalink)
| | Junior Member
| Quote:
Originally Posted by Bryan@ATS Diesel Like i've said before if you are set on using oil in your tank, put in a bit of two stroke oil. Its made to burn so chances of messing something up with two stroke oil is not as likely as it would be if you were using ATF (alot thicker than two stroke). Plus if you happen to get dipped with the ATF in your tank, then you can get a pretty good fine (PER GALLON). Diesels are not made to run with oil in the fuel so you will be taking a gamble with a $40,000 piece of machinery |
X2 Not worth the trouble. Just better off to recycle the used motor oils at your local auto parts store. Not to mention again that motor oil IS NOT designed to burn in any engine - I would like contact when you have excessive carbon deposits and/or injector issues. I will stick with what works--- Diesel Kleen. |
04-29-2008, 08:43 PM
eBay Motors
#9 (permalink)
| | Senior Member
| There are a set of stock lbz injectors on ebay for about $1000 right now. Probably want to get those if you run oil in your gas tank. Putting oil in to the tank will destroy the injectors. Just spend some money, and get proper fuel addative. There are a bunch of good ones out there, I use Stanadyne in everytank. Might back off to every other tank. |
04-30-2008, 09:14 PM
eBay Motors
#10 (permalink)
| | Senior Member
| Second on the stanadyne..that is all I recommend. It has worked wonders for clearing up clogged injectors. |
| Advertisement
