| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 06-07.5 LBZ & LLY Performance Parts Discussion Discussion of Performance Parts For the 06-07.5 LBZ/LLY Duramax Trucks No Advertising |  |
04-26-2008, 02:53 PM
eBay Motors
#1 (permalink)
| | Junior Member
| Finger stick hey guys i just bought the egr blocker plate and fingerstick. I am just wanting some advice on the fingerstick install so that it goes as smoothly as possible. Any help is appreciated. Mike
__________________ 06 cc lb 4x4 lbz
mbrp 4" turbo back
PPE Standard
cognito upper a arms
AFE intake
B&W hitch
air bags
blocked and fingered |
| Advertisement
04-26-2008, 04:59 PM
eBay Motors
#2 (permalink)
| | Senior Member
| Just take your time and you'll be fine. Make sure to solder all connections. I have a diagram if you are interested. Hope this helps.
__________________ 07' GMC CC/SB Diamond Eye direct downpipe, 4" Mbrp DP back, Airaid CAI w/Amsoil dry filter and prefilter, fingered and blocked, Transgo Jr, UDP tie rod sleeves, Cognito braces, H2's w/285 BFG's, Airdog 150, EFI Live, Autometer phantom boost and pyro |
04-27-2008, 07:40 AM
eBay Motors
#3 (permalink)
| | Junior Member
| thanks, gmclbz. this wiring stuff just makes me nervous.
mbrp 4" turbo back
PPE Standard
AFE intake
B&W hitch
air bags
04-27-2008, 08:09 AM
eBay Motors
#4 (permalink)
| | Senior Member
| No worries, it's really not that bad.
05-02-2008, 06:39 AM
eBay Motors
#5 (permalink)
| | Junior Member
| finger stick GmcLbz , can you send me that diagram , I;ve got to install mine and any wiring help is appreciated, Thanks |
05-02-2008, 07:33 AM
eBay Motors
#6 (permalink)
| | Senior Member
| I installed one on my buddy's 06-LTZ - The directions they send are very good. Just take your time and match up the wire colors as per the instructions. I was able to snip off some of the excess wire so that putting everything back in the factory harness was a bit easier. When finished, you couldn't tell anything had been changed. Like they said, make sure you solder the connections. Some nice black wire ties will come in handy for the prodject. Start to finish it took me about 2 hours, but I am very fussy and check everything 2 or 3 times before making a move.
__________________ HAD - 94 Chevy Dually 4x4 - 6.5 Turbo
96 Chevy Ext.cab 4x4 - 6.5 Turbo
99 GMC Dually 4x4 - 6.5 Turbo
HAVE - 2005 GMC Sierra crew/6'box - 4X4 - Duramax w/Allison. Fully loaded - AiRaid intake - 4" Pinnicle Performance Exhaust (No Converter - Straight through muffler) - EGR blocker plate - Edge Juice w/attitude - 2" plug in Turbo Resinator - |
05-07-2008, 02:07 PM
eBay Motors
#7 (permalink)
| | Junior Member
| green / yellow a bit of confusion on where the green/yellow conects to the yellow. Hard to tell by diagram. Thanks guys |
05-07-2008, 06:12 PM
eBay Motors
#8 (permalink)
| | Junior Member
| finger stick Well installed the blocker plate and finger stick on the 2007 lbz. Everything soldered. red to pink gray to gray, the yellow cut and yellow from finger stick to yellow to maf, then on two wire side, blue to brown/ wht and the green/ yellow to the cut yellow running across the engine. Getting the check engine light and will not got out. have ran through key cycle many times with light still on. Any help greatly appreciated |
05-09-2008, 10:16 AM
eBay Motors
#9 (permalink)
| | Senior Member
| Wish I could help you, but I don't have the directions anymore. However, I think we had the same problem at first and it went away after awhile. Like I said, it was on my buddies truck and he is checking for the directions we had. I'll let you know as soon as we find them, but I don't think you did anything wrong.
| Advertisement
