I was looking around under my new pickup while I was installing my B&W hitch and noticed no wires going into the cat. Does that mean if I delete it, it wont through any codes? I didn't pay any attention downstream if there was another sensor at the muffler. I had to go 400 miles to pick up my 5er toy hauler and was a little disappointed in the fuel mileage. I was very impressed in how easily it towed the trailer, lots of power, but got 6 mpg doing 73 mph. I was just happy it could pull the trailer that fast. Slowing down on the backroads at 55 mph I was getting 9 mpg. Thanks for your help.
__________________ 2007 Chevy 2500HD Crew Cab, Short Bed, Duramax LBZ
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP
You might get a low egr flow code if you delete it, but it is not a problem. It will not cause any performance problems and can easily be blocked with most tuners.
__________________ KYLE
That is some really nasty MPG's there!! Definately go with a larger turbo back system and check out the intake. Either replace with a cold air intake or at least do the mods on the air box. Like Pysco said, a good tuner will also help and the one he has is a good one.
Thanks for all the responses. Is there a cold air intake system that doesn't use air filters that need the conditioners like a K&N filter? I used to have a K&N, but I was having to clean it way to often, because I live in a very dry dusty climate. My old truck I just tore the hole box out and shoved an air filter used in a piece of equipment with a 4" hole in the end of the hose that went to the turbo. Thanks again.
I suggest an AFE Pro Dry S intake kit or AEM. Both use dry filter elements that do not require re-oiling. Let me know if you are interested, I can put you together a package price with everything you need.
