| Premium Membership | |
| | | 06-07.5 LBZ & LLY Performance Parts Discussion Discussion of Performance Parts For the 06-07.5 LBZ/LLY Duramax Trucks No Advertising |  | |
07-16-2008, 02:07 PM
eBay Motors
#11 (permalink)
| | DF Sponsors
| If your tranny or converter is not slipping, then most likely will not improve ET much, if at all. What it will do is allow more HP to be added for faster times. |
| Advertisement
07-16-2008, 02:48 PM
eBay Motors
#12 (permalink)
| | Junior Member
| Hey Was Your 11.89 Run In 4 Wheel Drive?
__________________ 2007 CREWCAB triple dog with crazy larry tune, volant , k&n air intake. 22'' rock stars on dune grapplers. |
07-16-2008, 02:53 PM
eBay Motors
#13 (permalink)
| | DuramaxForum Veteran
| From the looks of the vid it was a 4 wheel drive pass. Almost everone drag races in 4 wheel drive. If you do not you just smoke your tires like crazy.
__________________ John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me. NO TALKING JUST LINE IT UP |
07-16-2008, 03:07 PM
eBay Motors
#14 (permalink)
| | D-Zule Vin-door
| I know a lot of you guys race in 4HI but I am still convinced that with a sticky enough tire, and proper suspension setup, running in 2WD will give you a higher MPH and lower ET. The fastest diesels in the world are, you guessed it, 2WD !!!
__________________ See site for current sales/promotions. Name: Mike Email: 4x4Fantasy@gmail.com Phone: (703) 932-1197 |
07-16-2008, 03:30 PM
eBay Motors
#15 (permalink)
| | Junior Member
| When You Take Out The Torsion Bar Bolts You Lose The Allignment Is That A Problem At The Other End Of The Track At 100mph? Someone On Here Said To Do That To Get The Front To Hook Up Because I Still Spin In 4 Wheel!!
07-16-2008, 03:39 PM
eBay Motors
#16 (permalink)
| Quote:
Originally Posted by 4x4Fantasy I know a lot of you guys race in 4HI but I am still convinced that with a sticky enough tire, and proper suspension setup, running in 2WD will give you a higher MPH and lower ET. The fastest diesels in the world are, you guessed it, 2WD !!! | Those trucks and railes are runnin big slicks. You can not fit a tire that big in a stock wheel well. The fastes diesels you are talking about are dragsers. If the back of your truck is not tubbed you need 4x4 to get it to hook.
07-16-2008, 05:13 PM
eBay Motors
#17 (permalink)
| | DF Sponsors
| Yes 4x4 launch. I lower the T-bars until they are level. |
| Advertisement
