EGR delete?? - Chevy and GMC Duramax Diesel Forum
Old 01-19-2011, 08:10 PM   eBay Motors  #1 (permalink)
biggreenlbz's Avatar
EGR delete??
Whats the advantage of getting the EGR delete my local diesel shop said he would put it in for 15 bucks, but im kinda clueless on why i would want/need it. can someone tell me whats the reason to get it or not to get it????
Truck: 2006 Chevy Duramax LBZ ECSB
Lift: 8in Pro Comp
Tires and Wheels: 37/13.50/20
Tune: EFI live by Rob Coddens
Exhaust: 4in Silverline TB straight pipe 8in tip
Intake: Volant Cold Air
Other: EGR Blocker Plate
Lights: All on mod Recon smoked cab lights
Sound: Avic 700bt(modified) Two 12in Kicker L5s in ProBox Alpine M1000 Amp
Tint: 5% all around 35% windshield
biggreenlbz is offline   Reply With Quote Quick reply to this message
Old 01-19-2011, 08:18 PM   eBay Motors  #2 (permalink)
the egr/cooler delete on my 2011 gave me an extra 3 mpg.
The way I was told is that the egr works for an engine, is just like if a human was to live by inhaling his own farts, can't be good.
2011 sclb 6.7 cummins
2" level- egr/cooler delete- xrt pro w/ overdrive
5" flo pro tbe - fuel rail plug - airdog II
inline67 is offline   Reply With Quote Quick reply to this message
Old 01-20-2011, 08:23 AM   eBay Motors  #3 (permalink)
Unbelievable. Never heard put like that but I'll be getting my egr delete done asap. Iv heard that its not really noticeable but like I say mine is not done yet. I have the plate just not installed.
Traded my tuned LBZ for a 2013 Denali HD. 2500.
Waiting to tune Gale Banks is still a criminal!
cnsickles is offline   Reply With Quote Quick reply to this message
Old 01-20-2011, 08:46 AM   eBay Motors  #4 (permalink)
lddrew's Avatar
i've heard people claim their mpg goes down some with blocker or delete...
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline   Reply With Quote Quick reply to this message
Old 01-20-2011, 08:49 AM   eBay Motors  #5 (permalink)
I Sell Fireworks!
pyromax1012's Avatar
I'm sure that $15 will get you a blocker plate but realize that your Service Engine Soon light will come on until you delete EGR out of your programming via EFILive.
2011 Chevrolet Silverado LT 4X4 ECSB
Still has that new car smell...
2003 GMC Sierra 2500 H/D LB7 (SOLD)
181K, AT, AMSOIL OIL AND AIR FILTER
pyromax1012 is offline   Reply With Quote Quick reply to this message
Old 01-20-2011, 08:50 AM   eBay Motors  #6 (permalink)
freindly1's Avatar
This stops putting soot from exhaust in through Turbo and into engine. These are bad for engine and can cause premature wear from Foriegn Materials into the clean engine. Also a second item to perform is the PCV vent mod also helps keep engine cleaner.
2005 CCSB LT (LLY)
EFI Live with Dsp5 thanks to Idaho Rob
Banks Monster Duals Cat Back (4 inch)
Suncoast 5spd tp 6spd Conversion
Pillar Autometer EGT and Booster
Banks LBZ Ram Air INTAKE
MBRP ss Cat delete
Banks Scoop Tube
LBZ Mouthpiece
HID 9005 8000K
EGR Blocker
Air Horns
freindly1 is offline   Reply With Quote Quick reply to this message
Old 01-29-2011, 08:43 AM   eBay Motors  #7 (permalink)
Someone have the links to the DIY`s?
91backinblack is offline   Reply With Quote Quick reply to this message
Old 01-30-2011, 04:40 PM   eBay Motors  #8 (permalink)
LsUtIGeRs's Avatar
http://www.kennedydiesel.com
once you get on the site got to dmax performance, then pick what engine you have and
click on egr blocker. then click on the install intructions.
Mike
LBZ|6"|Toyo AT|Fuel Mavericks
Custom Pearl Paint
S&B CAI|5" MBRP Exhaust|BD Power Pup|PPE Shim Kit|Profab EGR Delete|Profab DP|LML Manifold|PCV Re-route|Cobalt Boost & Pyro
Bilstein 5100 & Stabilizer|Krypto Tie Rods|Moog Pitman|Idler Arms|Krypto UCA
Mag Hytec Diff Cover
LsUtIGeRs is online now   Reply With Quote Quick reply to this message
Old 01-30-2011, 04:54 PM   eBay Motors  #9 (permalink)
mwar410's Avatar
In theory you should get more power. Your cylinders are filling with 100% combustables, right? no inert gasses.
GMC 4.5 lly ext cab SLT
EFI live ATP,
4" magnaflow catback, magnaflow down pipe, pcv reroute,nicktane filter adapter, Fuel valve shimmed,duramax tuner LBZ induction kit, BD High flow manifold,SDP full EGR delete w/ LB7 up pipe
load controller 5000 bags, pitman and idler braces, kryptonite sleeves, cognito UCAs leveled with 315/70/17's and a little rub
Cen Pe Co diesel max fuel additive,Cen Pe Co oil
mwar410 is offline   Reply With Quote Quick reply to this message
Old 01-30-2011, 06:39 PM   eBay Motors  #10 (permalink)
Kemper's Avatar
i did the egr delete on my truck a few months ago.. just blocker plates.. check engine light never came on.. i did it cause i didnt want all the soot going through the intake valves.
As long as you don't get traction, you won't break a thing.
Kemper is offline   Reply With Quote Quick reply to this message
