Old 09-13-2008, 09:57 PM   eBay Motors   #1 (permalink)
WylieD
WylieD's Avatar
BD Manifold..
Gonna be installing one soon on my truck and was just wondering how easy or hard it is to do and maybe some tips to make it easy
07 Chevy Duramax CC SB LBZ
5" Exhaust
Banks Ram Air Intake
BD Manifold
EGR Blocker
Diablo Sport
B&W Turnover
5% Tint All Around
Line-X Bed Liner
WylieD is offline   Reply With Quote
Old 09-13-2008, 10:29 PM   eBay Motors   #2 (permalink)
rj998
rj998's Avatar
I was told that it wasnt bad, but romeving the alum. intercoler tube makes it alot smoother project, hope that helps!
07 classic 4dr c/c sb black. 4" s/s straight piped 6" tip. trans go jr. by me. cal-tracs. ppe air box mod. ppe hot+2 et level 4 (225) oru leveling keys. bilistin shocks. fuel rail shim. egr blocker. pvc reroute. edge insight gauge. M/T classic 17x9 with dick cepek mud country 33x12.5x17
Best e.t. 13.95 @ 94 mph w/1.88 60 foot w/33" tires and no sleeves
Fass 150, cognito and sleeves
Next mod tranny by me,sun coast products from idaho rob
New best e.t. on level 5 300hp
13.15 @ 101 mph w/1.80 60 foot w/33" tires
rj998 is offline   Reply With Quote
Old 09-14-2008, 12:33 AM   eBay Motors   #3 (permalink)
Landscapeman
Save Water, Drink Beer
Landscapeman's Avatar
It is easier when you take out the steering column. It still will be a b*tch. Make sure yoy have a good torque wrench and Sh*t load of patience. Good Luck
2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
Landscapeman is offline   Reply With Quote
Old 09-14-2008, 11:13 AM   eBay Motors   #4 (permalink)
WylieD
WylieD's Avatar
I knew it wasnt gonna be fun and easy but a guy can only hope
5" Exhaust
BD Manifold
EGR Blocker
Diablo Sport
B&W Turnover
5% Tint All Around
Line-X Bed Liner
Old 09-15-2008, 12:10 PM   eBay Motors   #5 (permalink)
RCH
RCH's Avatar
It wasn't too bad. Remove the fender liner, remove the bolt in the steering shaft so you can slide the shaft out of the way. remove the large tube that goes from the front to the turbo charger. You will be able to reach all the manifold bolts now.
2007 GMC K3500 Classic LBZ/Allison, SRW, 4WD, Ext. cab,Sport Metalic Red, FS2500 bybass oil filter
Deep transmission pan/w Transynd
Cognito idler/pitman Arm Braces
EGR Blocked with Fingerstick
PCV Re-Routed, Fuel Filter Bleeder kit
MBRP 4" SS cat back exhaust
BD performance exhaust manifold
4Wheel Pop-Up Camper
AUX. input for my MP3 Player
RCH is offline   Reply With Quote
Old 09-15-2008, 12:16 PM   eBay Motors   #6 (permalink)
05 3500 2wd
05 3500 2wd's Avatar
.I just did mine yesterday and the others are correct about removing the tube from the turbo to the intercooler and take out the bolt in the steering shaft and push it up into the column and drop the other shaft down. The bolts are tight and I had to get a hammer and hit my wrench to break some of them loose. When you get the heat shield off you will want to hammer / reshape it to the new manifold so it is easy to get the bolts in it before you install the manifold. Don’t forget to look closely at the inner fender from the underside and push back the harness clip attach points so you don't yank the harness.
Clifford is a 2005 GMC Loaded SLT 2wd with; Killer Bee true cold air intake and ported intake overhaul kit, Diamond Eye down pipe, BD drivers side manifold, Silverline 4" S/S straight piped exhaust, EGR Blocked, Bully Dog Programmer(PPE On the way) with pillar mounted outlook monitor, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, Rear mounted under the bumper halogen lights for trailer loading, (and them night time tail gaiters) Put co S/S mud flaps, Put co Racer front grill cover (removed for them 105 deg summer days), Compete interior wood dash kit including console and steering wheel, Dual Liner 3 piece bed liner with rubber floor mat, Tail gate lock, Roll-N-Lock tonne cover, and AVS in channel vent visors.
05 3500 2wd is offline   Reply With Quote
Old 09-15-2008, 03:47 PM   eBay Motors   #7 (permalink)
aggar
aggar's Avatar
Penetrating oil and patience and a few beers and you'll get it!
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058(Fleece Performance), SC Case Brace, 68mm Cheetah, EFI Live, HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
2001 Ext Cab LB 2500hd Lb7. BoneStock! ( For Now)
Old 09-15-2008, 05:36 PM   eBay Motors   #8 (permalink)
duramax-rob
duramax-rob's Avatar
Use PB Blaster to Pre-soak the Nuts. Also to help run them off. Got that trick from tractor forum. Another trick is to heat the nut just hot enough to melt bee's wax prefferly or candle wax on the nut and stud. Comes off a whole lot easier than liquid wrench.
duramax-rob
__________________________________________________ __________________________________________________ _
2001 Chevy 3500 CC Longbed Dually 4X4, 6.6 Duramax, Hypertec Programmer, Magna Flow 4" Exhaust, 5th wheel hitch, Jayco 32' 5th Wheel
Some's good, More's better, Too much is just enough!!!!
duramax-rob is offline   Reply With Quote
Old 09-15-2008, 07:02 PM   eBay Motors   #9 (permalink)
FH Leader
FH Leader's Avatar
take out the fender and the steering shaft after that it is all clear. depending on how many miles are on your truck will be the big factor if it is easy or not. all my bolts came out real easy.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd
Omaha Truck and Trailer offering Woodworth custom build trailers.
Now a factory authorized Whelen dealer
My iron is yellow
FH Leader is offline   Reply With Quote
Old 09-16-2008, 12:52 PM   eBay Motors   #10 (permalink)
RCH
RCH's Avatar
Before you put it back together, look at the wiring harness to see if it is rubbing through on you fender liner. Some have had that issue, it will eventually short out your computer. Mine was rubbing so I wrapped a piece of hose and some electrical tape around it to protect it.
