Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Turbo's Stock and Aftermarket.
Turbo's Stock and Aftermarket. Place for all your turbo questions
Old 09-20-2008, 09:28 PM   eBay Motors   #11 (permalink)
deeretracks
The Sheriff
deeretracks's Avatar
IMO I would find a turbo shop or take it to a dealer and have it looked at. Or contact ATS diesel and see if they can help you http://www.atsdiesel.com/ats_new/
Craig
2001 Chevy, 4 door, short bed,D-Max, 2 wd.
Special Thanks goes to the person in the WAL-MART parking lot for installing it for me,
Old 09-22-2008, 07:31 AM   eBay Motors   #12 (permalink)
Killerbee
Killerbee's Avatar
Before you go spending money on this, return your intake to stock. Make sure the MAF is clean.
EGT complaints? What is high to you?
33 psi? Stock boost is around 20.
WANTED, ALLISON TRANNY CORE CHEAP
Michael, 2500HD LLY
Vehicle Systems Engineer-useful links
THERMAL FEEDBACK INTRODUCTION
PERFORMANCE AND COOLING
WWW.MaxxTORQUE.com No Fluff
OVERHEATING?
T.F. LOOPS IN BLOWN APPLICATIONS
EFILive TUTORIAL Home of the First Ever VGT "wastegate" tune
Old 09-22-2008, 07:55 AM   eBay Motors   #13 (permalink)
aggar
aggar's Avatar
Stock boost on an LBZ at wot should be close 27-28 psi. Look up Fleece performance.com and talk with Brayden. Tell him Ryan Neal sent ya.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058(Fleece Performance), SC Case Brace, 68mm Cheetah, EFI Live, HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
2001 Ext Cab LB 2500hd Lb7. BoneStock! ( For Now)
Old 09-22-2008, 08:00 AM   eBay Motors   #14 (permalink)
timespentsearching
timespentsearching's Avatar
with a turbo contoller you can run up to 40 llb of boost on the lbz. i would recommend going that high but 35 is pretty safe.
Diamond Shocks
Tuner: Banks Six-Gun with PDA
Exhaust: Diamond Eye 5 inch system
Airtake: modded stock box (banks with scoop in the future)
Turbo: Stock, PPE boost valve
Transmission: Stock,
Tires: 235/85R16 Firestone transforce AT
timespentsearching is offline   Reply With Quote
Old 09-22-2008, 08:49 AM   eBay Motors   #15 (permalink)
aggar
aggar's Avatar
I can hit 40 psi. on my Cheetah with no boost controller.
Old 09-22-2008, 08:05 PM   eBay Motors   #16 (permalink)
mikes454
i hit 35 psi easy 1/2 throttle?the maf is spotless.i'd swear it was the turbo vane controls too but no dtc???i dunno i'm learnin to live with half a gas pedal looks like...
06' silverado crew cab long box //6.6LBZ//6" bds lift w/gm lift keys//37" pitbull rockers//edge juice w/attitude//4inch straight exhaust//K&N cold air kit//"winchready"front bumper//
mikes454 is offline   Reply With Quote
Old 09-23-2008, 06:48 AM   eBay Motors   #17 (permalink)
Killerbee
Killerbee's Avatar
you might have a melted MAP sensor, but could be other things also. You need to log it with EFILive. Take that edge off, and get a real tuner.
Michael, 2500HD LLY
OVERHEATING?
Old 09-23-2008, 09:35 PM   eBay Motors   #18 (permalink)
mikes454
lol thanks guys i appreciate all the suggestions.newest theory...is it posiible the engine computer has already been hopped up with a handheld removable tuner and now the edge is "stacked" with that program?oh and a crappy MAP would throw a dtc for sure right?wait i checked the MAF mass air flow sensor in the intake tube when i put on the k&n last week, whats a MAP?
Old 09-24-2008, 07:49 AM   eBay Motors   #19 (permalink)
Killerbee
Killerbee's Avatar
MAP-manifold absolute pressure.
On your truck, I think it is located near the grid heater, post CAC, pre-plenum. Do not confuse with MAF. However it would be good to compare your MAF value with your MAP/rpm values.
MAP sensor failure is not usually a complete failure, however the liklihood that yours is bad is still remote. It can happen on seriously overboosted vehicles, the higher heat damages them.
If you had an inadvertent stack, yes that would explain it also. Sounds like you need EFILive to ascertain the status of your PCM.
Michael, 2500HD LLY
OVERHEATING?
