HELP: Dead batteries that are brand new - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 11-16-2011, 09:00 AM Thread Starter
Hello all, I have a 2006 duramax and a few weeks ago I come out and when I turn the key over it just clicks. Okay so I assume it's batteries. So I go and buy two brand new batteries and all has been well up until today.I noticed the past few days when I first start the truck the battery voltage seems to about around 10-12and once I start driving it goes up to past the 14 volts mark. Well I go out this morning to start and they are dead again, just clicks. What in the world could this be? I don't have an aftermarket cd player or anything.
Chad3304 is offline
post #2 of 16 (permalink) Old 11-16-2011, 09:16 AM
Im Superrrrr!
jmaz268's Avatar
Send a message via Yahoo to jmaz268
You could have a bad alt....do a load test on it....could be a module not properly going to sleep and leaching power as well.
Goes by John
--2001 ECSB
SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more
Sponsored by Creatures of the Night Performance and SDP
--2005 CCLB Dually
The tow pig
Tuned and Edge Insight CTS
jmaz268 is offline
post #3 of 16 (permalink) Old 11-16-2011, 09:17 AM
WisconsinMAX's Avatar
Mine sat for 2 days and I came out and just clicks. Service brake system flashing on the DIC. Charged em up and load tested them and it said the batteries are fine?
Sent from my Android phone while not driving...
Andrew
2006 Chevy LLZ
ReadyLift|EFI Live tuned by DDP|Autometer|
AFE|MBRP|RBP|PPE|Transgo Jr|Cognito|AVS|WeatherTech
Waiting install:cab lights, building traction bars, Airdog, ATP Autocal!
Thanks ATP,ADP, & MA
WisconsinMAX is online now
post #4 of 16 (permalink) Old 11-16-2011, 09:18 AM Thread Starter
I thought about the bad alt as well, no CEL's or anything that come on, I'm going to attempt to jump it and go to a parts store and see if they can test my alt.
Chad3304 is offline
post #5 of 16 (permalink) Old 11-16-2011, 09:22 AM
danhr's Avatar
If you charged them up and then load tested them it self defeats the point of testing them.
Do you start your truck after you charge the batteries? No... you start your truck after it's sat for awhile. So try letting them sit (not on concrete btw) for a few hours and then come back and put the load tester on them.
At least that's how I always tested mine, if the symptoms are that of a dead battery and the charging system is up to par.
2007.5 2500HD CC/SB LTZ
498 rwhp, 845 rwtq
DiamondEye 4", EFI Live by BobO, Edge Insight CTS, S&B Intake, Bilstein 5100 shocks, MOOG idler/pitman with SS support, Raptor 150, P553207, !PCV, !EGR, Transgo Jr, Rare Parts tie rods, 55 watt 4.5k HID low/hi/fogs, Belltech 3" lowering shackle
danhr is offline
post #6 of 16 (permalink) Old 11-16-2011, 09:24 AM
danhr's Avatar
More than likely it's not your alternator... if your volts go up to 14 with the truck running (and you verified this with a multi-meter... not the inaccurate analog gauge on the cluster), then your charging system is most likely working. If you were running off your batteries, it would be at most 12VDC
Did you check to make sure your battery connections are clean and tight?
498 rwhp, 845 rwtq
danhr is offline
post #7 of 16 (permalink) Old 11-16-2011, 09:24 AM
Dont own a load tester. Just dtove it to the autoparts store. Do you have to disconnect the batteries from each other since there parralleled?
Andrew
2006 Chevy LLZ
post #8 of 16 (permalink) Old 11-16-2011, 09:27 AM Thread Starter
Okay im confused because I don't know if the replies are towards me or the other guy with battery problems, no offense would have been easier had he started his own thread. But to dan I used the gauge on the cluster for my readings. It was around 12 and stays there until I drive a little then it goes up?
Chad3304 is offline
post #9 of 16 (permalink) Old 11-16-2011, 09:34 AM
Sorry just looking for help as I put a thread up and posted in another battery problem thread with 0 replies. Seems were having the same problem?
Andrew
2006 Chevy LLZ
post #10 of 16 (permalink) Old 11-16-2011, 09:36 AM Thread Starter
no problem man, yeah I just went back and read your first post it does seem to have the same problem so might as well stick to one thread lol.
Chad3304 is offline
