DTC Glow plug problem - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 12-27-2011, 01:54 PM Thread Starter
tmm403's Avatar
Ok, last month I got a engine light come on and I go to check it out and it said "cylinder 7 glow plug". No biggie, I change it and reset the codes and now it says "cylinder 7,3 glow plug". Ok maybe the cylinder 7 glow plug was bad. So I order some more and last weekend, I changed the 3 and 7 cylinder glow plugs and still getting the same message. Also before, the glow plug light will stay on for a long time. Usually it would take 3 secs and it will turn off. I did hear something about the glow plug module going bad and it will make the light do a 18 sec delay. Could it be the module? This happen to anyone? Please help!!!
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids.
tmm403 is offline
post #2 of 10 (permalink) Old 12-27-2011, 03:41 PM
rebpdt's Avatar
could be, but it will throw another code
you can check it with a test light. hit the contacts while someone works the key
CCSB LB7 4x4
rebpdt is offline
post #3 of 10 (permalink) Old 12-27-2011, 03:47 PM
Baadgoat's Avatar
Sounds like the glow plug module to me, seen this before on customers trucks. I'd test it before condemning it though.
2006 CCSB LBZ- EFI Live | Sinister EGR Delete | ADII 165 | MBRP 4" | American Force 22x12 | 33" Toyo MT | Amp Research
2007.5 CCSB LMM- SOLD
2006 CCSB LBZ- SOLD
2005 CCSB LLY- SOLD
2003 CCSB LB7- SOLD
Baadgoat is offline
post #4 of 10 (permalink) Old 12-27-2011, 07:08 PM
Administrator
jc1843's Avatar
Maybe you changed the wrong one--- Just to post something.
driver's side-- 2-4-6-8------Passenger side 1-3-5-7. So #7 in under the fuel filter.
The 06 trucks did have glow plug problems-- GM did do many on warranty, and had a TSB for a reflash.
Moved to LBZ, not a 911 problem.
jc1843 is online now
post #5 of 10 (permalink) Old 12-27-2011, 08:14 PM Thread Starter
tmm403's Avatar
Really...I thought it was the other way. I think I will just change all of them.
tmm403 is offline
post #6 of 10 (permalink) Old 12-27-2011, 08:50 PM
Bobo
DieselX-Bob's Avatar
EFILive tuner
DieselX-Bob is offline
post #7 of 10 (permalink) Old 12-28-2011, 01:15 AM
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
If you need a set let us know and we will get you a set shipped out. I have to replace 4 myself but just doing all 8 and being done with it.
Name to come
2013 GMC Denali HD 2500 ccsb,100%stock,spray liner,B&W,
Sold not forgotten
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
11.53 @ 116.92 1.66 60's
Custom ECM & TCM Tuning for 2001-2010 LB7/LLY/LBZ/LMM trucks
by Tony Martino at Ridge Runner Diesel available here-
EFI Live Products
ripmf666 is offline
post #8 of 10 (permalink) Old 12-28-2011, 08:59 AM Thread Starter
tmm403's Avatar
Thanks for the help. I have extras and will replace tonight when I get home. Thanks guys
tmm403 is offline
post #9 of 10 (permalink) Old 12-28-2011, 03:03 PM
Administrator
jc1843's Avatar
GM numbers the cylinders from the front to the back. So if you look at the back of the engine-- the driver's side head is further back, and closer to the firewall. The passenger side head is further forward. so that starts the numbers-- as #1.
The other V8s from General are different, and #1 on those, is the front on the driver's side.
post #10 of 10 (permalink) Old 12-08-2014, 06:58 PM
I have a 2011 Silverado 2500HD Duramax LML and my number 7 glow plug threw a code. It only has 79000kms on it. Could it just be a faulty one? How long should they last? This is my first diesel.
tycurtis7063 is offline
