CODE: "Low Fuel Rail Pressure"??????? - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 01-01-2012, 06:02 AM Thread Starter
DmaxCop's Avatar
07' Chevy 2500hd
Edge Controller is showing a code of "Low Fuel Rail Pressure" also the dash has a blinking message that "Power has been reduced" anyone have any idea of what this might be?
was driving the truck home from work and the truck will not go over about 50mph and the message was flashing along with the engine light was displayed. Checked the code retrieval on my edge unit and there it showed the message of Low Fuel Rail Pressure.......
DmaxCop is offline
post #2 of 20 (permalink) Old 01-01-2012, 06:53 AM
danhr's Avatar
did you recently turn the level up on your edge?
2007.5 2500HD CC/SB LTZ
498 rwhp, 845 rwtq
DiamondEye 4", EFI Live by BobO, Edge Insight CTS, S&B Intake, Bilstein 5100 shocks, MOOG idler/pitman with SS support, Raptor 150, P553207, !PCV, !EGR, Transgo Jr, Rare Parts tie rods, 55 watt 4.5k HID low/hi/fogs, Belltech 3" lowering shackle
danhr is offline
post #3 of 20 (permalink) Old 01-01-2012, 07:04 AM
Try a bottle test right away and see if it's your FPRV.
Beyond that you'll need a someone to read fuel rail pressure (Tech 2, EFI V2, Edge Insight, etc) to see what's going on.
MTL_Dmax is offline
post #4 of 20 (permalink) Old 01-01-2012, 07:07 AM Thread Starter
DmaxCop's Avatar
yes
DmaxCop is offline
post #5 of 20 (permalink) Old 01-01-2012, 07:08 AM Thread Starter
DmaxCop's Avatar
A bottle test???? I am totally new to the diesels and have no idea what you are talking about sir...
DmaxCop is offline
post #6 of 20 (permalink) Old 01-01-2012, 07:10 AM Thread Starter
DmaxCop's Avatar
yes, i switched it from tow mode to race???
DmaxCop is offline
post #7 of 20 (permalink) Old 01-01-2012, 07:13 AM
No worries, we all started somewhere. The FPRV (fuel pressure relief valve) opening prematurely is more common with earlier trucks, but still worth eliminating. If it does, you will lose your fuel rail pressure and the truck will go into limp mode.
The best way to test the FPRV is the bottle test
On the drivers side fuel rail near the firewall there is a horse shoe shaped 1/4" hose close to the glow plug bracket. disconnect the hose closest to the drivers side where it comes out of the fuel rail. Then simply hook up long hose and clamp it tight and plug the "U" shaped hose.
Run the hose to somewhere that a bottle can be mounted. If your hose is long enough, you can mount it between the coolant tank, and airbox. This really doesn't matter just as long as you can have the bottle standing in a up right position.
Now drive the truck hard, with some wide open throttle runs.
After you do this, check the bottle. If its empty, or has a little fuel, your FPRV is not bleeding off fuel and you don't need to shim the valve.
If it has more than a little fuel, that means that your fuel rail relief valve is leaking and you will then need to either shim the valve, or install a race valve.
MTL_Dmax is offline
post #8 of 20 (permalink) Old 01-01-2012, 07:53 AM
poosniffer's Avatar
You may be draining your fuel rail with the added fuel demand required by the "race" tune.Switch back to a lower power level and see if that works.You may want to change your fuel filter as well if it has not been done in a while.
2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
post #9 of 20 (permalink) Old 01-01-2012, 08:04 AM
mutt511's Avatar
Mine has been rebuilt and shimmed tight and still blows when pulling hard. Think it's time to order a race plug.
06 Chevy 4x4 2500HD CC LBZ debadged
Straight piped EGR blocked
PPE hot+2ET programmer
air dog II
PPE Induction (AEM element)
super springs
fabtech tierods (soon to be redesigned)
20" moto metals(junk won't own another set)
Auto meter cobalt gauges (thanks to Holton @ alligator)
my work truck
mutt511 is offline
post #10 of 20 (permalink) Old 01-01-2012, 08:17 AM Thread Starter
DmaxCop's Avatar
Thanks for the info, gonna switch it back to a lower setting and go get the fuel filter changed right quick and see what that does for it....worse comes to worse, I still have the factory warranty on it. I will keep ya posted...
DmaxCop is offline
