Not charging battery light - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 01-30-2012, 03:44 PM Thread Starter
A friend of mine just got his 06 duramax and his "not charging battery light" comes on at start up and goes off when he starts driving
Any ideas?
2006 LBZ
84,xxx miles
Superchips Flashpaq
3.5" straight pipe exhaust/dumped
Modified Air Intake with WIX air filter
Resonator Plug
ALHeadUSMC is offline
post #2 of 7 (permalink) Old 01-30-2012, 03:58 PM
Lincoln Diesel
Aaron@LDS's Avatar
Possibly a sticking regulator.
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #3 of 7 (permalink) Old 01-30-2012, 04:01 PM Thread Starter
How should he go about testing that
2006 LBZ
84,xxx miles
Superchips Flashpaq
Resonator Plug
post #4 of 7 (permalink) Old 01-30-2012, 04:03 PM
Administrator
jc1843's Avatar
Take the truck to Autozone-[and others] , they can test it on the truck.
jc1843 is online now
post #5 of 7 (permalink) Old 01-30-2012, 04:08 PM
Lincoln Diesel
Aaron@LDS's Avatar
You can also call someone that sells alternators, and ask how to test the regulator yourself. I know there is a way to jump power to one of the pins on the ALT, and this puts it under load. If you notice the alt working harder the regulator is not sticking. But for accurate results, you should do this when the truck would normally exhibit this problem.
-Aaron-
SOLD
post #6 of 7 (permalink) Old 01-30-2012, 04:22 PM
Administrator
jc1843's Avatar
The regulator is electronic and mounted inside the alternator. They usually work-- or they don't work.
post #7 of 7 (permalink) Old 01-30-2012, 06:03 PM
Lincoln Diesel
Aaron@LDS's Avatar
Yeah I know... I wish that was the case all the time! But for me, it worked after driving about 5-10 miles. Once it kicked in it stayed working. But I was told by my alternator salesman that they "stick sometimes." And replacing mine fixed it for me. I am just giving an opinion though. And I have an 01, so I don't know how everything works.
-Aaron-
SOLD
