Steering colum rattle? - Chevy and GMC Duramax Diesel Forum
post #1 of 103 (permalink) Old 05-24-2012, 03:42 PM Thread Starter
Hey guys anyone know how to sevice the steering column on an 06 lbz? Mine rattles. Thanks
blackmax001 is offline
post #2 of 103 (permalink) Old 05-24-2012, 03:44 PM
DrededSS's Avatar
It's your steering column bearing. GM p/n 88963617
'04 LB7 CCSB, Cognito 8", built engine and trans, MPI twins, 98mm BMW
'04.5 LLY CCdually, Cognito 6", Danville Tow Charger, Suncoast V, LBZ mouthpiece, AEM intake, EGR delete, FASS 150, Banks Intercooler, TxC V2 w/fan, 90 gallon transfer tank, double dynamatted interior, Frontier bumper replacements
'04 LB7 ECSB, Wife's truck, Cognito leveling kit, MKW 20's, Nitto Trail Grappler 33's, RDL mouthpiece, Tuning by Mark Broviak of Danville Performance, Parts from Nate at Performance Truck Products
DrededSS is offline
post #3 of 103 (permalink) Old 05-24-2012, 03:55 PM
bluecollar's Avatar
A buddy of mine put a 2inch pipe clamp one his 06 under the dash ont the colum and squeezed it very little and took the rattle away..
03 crew cab.. stage 5 trans. .efi live. lift pump.lbz pump and reg. head studs. tie rod sleeves.. traction bars. Dts 64mm ihi, 40% exergy injectors, 599hp/1087tq
Big thanks to DTS & Steve at ssdiesel tuning
bluecollar is offline
post #4 of 103 (permalink) Old 05-24-2012, 05:46 PM
DrededSS's Avatar
A new bearing is an easy swap. Unbolt the steering shaft, slide the old one out of place and pull it, then reinstall the new one. Should just take a few minutes if you're handy at all with tools.
DrededSS is offline
post #5 of 103 (permalink) Old 05-24-2012, 06:11 PM
eric-satx's Avatar
Do yourself a favor and do the bearing and intermediate steering shaft at the same time.
Intermediate Steering Shaft (Part#19153614)
And Upper Bearing (Part# 88963617)
2007 LBZ, Tie Rod Sleeves, Pitman & Idler Arm supports, Pump Rub fix, Bilstein 5100s , Cognito UCAs, N-Fabs, Cabin Filter mod, Delayed Blower Module to dry evaporator, and a Power Steering cooler)
2006 Jetta TDI (daily driver)
eric-satx is offline
post #6 of 103 (permalink) Old 05-24-2012, 08:26 PM
nsolimini's Avatar
I put a pipe clamp and the rattle went away
2008 LMM CCSB LTZ 554HP 1015Torque
Sold2007 LBZ 2500HD Crewcab 4x4, EFI Live DSP5, TransGo Jr, Airdog II 165, MBRP 3" Downpipe, AFE intake, 4inch RBP turboback straight piped exhaust, egr blocked, PCV Rerouted, tie rods sleeved, 20inch Fuel Hostage, 305/55R20 procomp extreme A/t
SOLD2003 2500HD Ext cab LB7 4x4, EFI Live DSP5, PPE Boost Valve, Airdog 150, AEM HD intake, MBRP 5inch straight pipe, 20 inch eagle alloy 097, 33inch federal couragia mt
nsolimini is offline
post #7 of 103 (permalink) Old 05-24-2012, 09:05 PM
0--J-MONEY--0's Avatar
Can someone post a picture of how your pipe clamp is installed??
White 2007 Classic LBZ CCSB Fully Loaded LT3
Performance: EFI Live DPS5 by Idaho Rob, AFE intake, 5" Flo~Pro TB exhaust, Air Dog 2 165gph lift pump, fuel rail plug, tie rod sleeves, Alligator Diesel Performance radiator hoses, EGR blocker plate.
Exterior: Powdercoated H2's on 285 BFG A/T's, Bilstein 5100's, leveled tow mirrors, DDM tuning HID's w/ all-on-mod, 1500 series tailgate spoiler, UWS low profile tool box.
Interior: Autometer GM Factory Match gauges (boost, EGT, fuel pressure), DIY AUX cable mod.
0--J-MONEY--0 is offline
post #8 of 103 (permalink) Old 05-25-2012, 11:31 AM
There are a number of posts on this subject already but not in the powertrain section - steering or interior I think. That is where I found the idea for a worm drive hoseclamp on the white (or green?) plastic collar on the column under the dash. It doesn't take much tightening to remove most of the movement. It worked for me at least for now.
Dusty Trails is offline
post #9 of 103 (permalink) Old 05-30-2012, 03:42 AM
LsUtIGeRs's Avatar
I also did the pipe clamp and its eliminated 95% of the rattle. Look in the DIY section
Mike
LBZ|6"|Toyo MT|Fuel Mavericks
Custom Pearl Paint
S&B CAI|5" MBRP Exhaust|BD Power Pup|PPE Shim Kit|Profab EGR Delete|Profab DP|LML Manifold|PCV Re-route|Cobalt Boost & Pyro
Bilstein 5100 & Stabilizer|Krypto Tie Rods|Moog Pitman|Idler Arms|Krypto UCA
Mag Hytec Diff Cover
LsUtIGeRs is offline
post #10 of 103 (permalink) Old 05-30-2012, 05:32 AM
LHN...We ARE the Joneses
Clunk in 05' Steering Gone! Thanks DF
Hook'em_Horns! is online now
