Nervous about EGT probe install - Page 4 - Chevy and GMC Duramax Diesel Forum
post #31 of 40 (permalink) Old 07-06-2012, 08:35 AM
03 LB7's Avatar
Originally Posted by Blackcloud556 View Post
well unfortunately nobody figures out that they are not a good mechanic until its too late.
2003 GMC SIERRA 2500HD 4X4 DURAMAX
ARRIVAL BLUE REGULAR CAB
Edge Juice W/ Attitude, PPE Boost Valve, AEM Brute Force, 4in Exhaust
Western Ultramount 8 1/2 Pro
1994 GMC SONOMA: 5.7L V8, 5 SPD MANUAL
>>>SUPERCHARGED LS IN THE WORKS<<<
http://www.youtube.com/watch?v=yufWPxZ83JQ <- BURNOUT CONTEST
-Todd
03 LB7 is offline
post #32 of 40 (permalink) Old 07-06-2012, 05:17 PM Thread Starter
Varty Yo's Avatar
Well its done!!!!
Took me a little long cause the dam wheels liner is a little tricky with the dual hoop in there! Went smoothly except when the bit got stuck in the hole! i started a few sizes smaller and it was the 2nd one up that got stuck. Word of advice is just drill the 21/64's right off the hop! Other then that its in and working!
Thanks for the help guys
2006 LBZ
Mike L Stage Awesome!
Airdog2 165, 5" MBRP Turbo back
EFI Live tuned by Idaho Rob, DSP5, ATP
Cognito set at 8" Nor-cal Truck
Fox 2.0 shocks all around, Deaver 6" springs
SS idler support/ Rare parts tie rods
37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes
HID's All on mod/ AMP reaserch steps
Varty Yo is offline
post #33 of 40 (permalink) Old 07-06-2012, 09:21 PM
Painkiller's Avatar
Awesome!
2004.5 Silverado 2500HD 4X4, LLY, EFI Live by Idaho Rob, Banks intake, Dual bypass oil filter, 4" exhaust, AirDog 2 - 100, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
116k miles/31jul13
Yeasu 857D/ATAS-120A - "When all else fails..."
US Navy 1992-2012 Retired
Painkiller is offline
post #34 of 40 (permalink) Old 07-07-2012, 10:25 PM
KB3MMX's Avatar
Originally Posted by disom93 View Post
Ive never done it running. Ive done numerous with it shutoff with no problems
X2
All these home brew "special procedures" are pure BS. Drill and tap the damn thing like normal metal, it will be fine!
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #35 of 40 (permalink) Old 07-09-2012, 06:07 PM
JestaLBZ's Avatar
Originally Posted by KB3MMX View Post
X2
I used to run EDM in a die shop....take the plunge, I just did it too since I was down for a while...so no more "bone stock"...
Congrats, hope it helps you monitor ur truck.
SLT w/ American Luxury Coach Pkg.; Titan Class V rear hitch; SiriusXM; ISimple Connect Interface; In-Bed tool chest; MBRP 4" turbo back w/ muffler & 5" tip; Fuel Rail Plug; EGR Delete; EJ w/ Attitude; Raycor Fuel Filter; ADII 165; 2% Bio-Diesel each tank beeeeecause we now have A NEW CP3 (GM stock); (8) more Bosch/GM stock injectors; new fuel rails and new sensor and fresh ecm reflash 7/12....Thanks for the crappy injector pump GENERAL MOTORS and BOSCH!!..nice truck but you STILL SUCK and I'm STUCK with this Badass Truck!!...so (insert rhyme here!!!)....$7,127.23
JestaLBZ is offline
post #36 of 40 (permalink) Old 12-05-2012, 03:15 PM
Trace730's Avatar
I am new to the duramax forum as I recently purchased my truck in early fall. There is so much to learn and what i have discovered so far is how valuable this forum is and your experiences with your trucks. Thank you all for sharing and at some point I am just going to do this and feel confident about it, just wanted to share that with all of you who commented on this thread and the numerous other threads in this forum.
Thanks!
2004.5 lly Duramax -*- LBZ Mouthpiece - PCV Reroute -
Trace730 is offline
post #37 of 40 (permalink) Old 12-05-2012, 03:46 PM
chevyboy86's Avatar
I'm a machinist, I've helped do this couple times. We used a Mac tools vacuum thingy that hooks up to an air line. With the engine NOT running, I'm a machinist and I've broke drill bits as well. I would rig up a shop vac, wouldn't use any lube for the drill. But def use a little shot of "rapid tap" on the tap, it will help your tap create a better thread profile and less risk of a tooth breaking off or something. Better safe than sorry IMO.
07.5 Twin turbo LMM
RIP CAINER
chevyboy86 is offline
post #38 of 40 (permalink) Old 12-06-2012, 01:42 PM
SGMdmax's Avatar
Do you guys put any sealant on the EGT probe when you install it?
I'm getting ready to install one and the info here was a huge help.
2007 GMC Sierra Classic LBZ CCSB 4x4
LineX bedliner, Nasta SS Nerf Bars, 265/75R16 Revo 2 tires , front windows tinted to match rear, Tekonsha P3 brake controller, Bilstien 5100 shocks, MBRP 4" turbo back exhaust, Edge Insight CTS, EFI from ATP.
SGMdmax is offline
post #39 of 40 (permalink) Old 12-06-2012, 01:55 PM
I've been freakin out about this also but I guess I will just dive in and get it done.
speak2mlv is offline
post #40 of 40 (permalink) Old 12-06-2012, 02:12 PM Thread Starter
Varty Yo's Avatar
i coated the threads with antiseize
2006 LBZ
Varty Yo is offline
