Replacing glowplug 5, disconnect Battery? - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 10-08-2012, 06:40 PM Thread Starter
Do you have to disconnect the batteries before you change out the plug? Will the engine light go off after the repair or do you have to reset the code and if so how is it done?
Duistruck
-2007 GMC Sierra 2500 HD, Duramax Diesel
-Body Type: TK25743
-VIN: D97F13xxxx
-Super Duty Air Lift System
-B&W Companion Hitch
Duistruck is offline
post #2 of 19 (permalink) Old 10-08-2012, 07:35 PM
johnjohnson42's Avatar
Replaced 1, 3, 5, and 7 on mine a few weeks ago (3 was the one causing the engine light). Removed tire and fender liner so I could get to them easier. Did not disconnect the batteries and reset the code myself with EFI Spade Jack, but any autoparts place can reset them for you. I figure I'll replace 2, 4, 6, and 8 when one of them goes out.
2007 2500HD CC SB Classic 6.6 Turbo LBZ. EFI Live DSP5, MBRP Turbo Back Exhaust, MBRP Turbo Downpipe, PCV Reroute, S&B Cold Air Intake, Alligator Transmission Cooler Lines, Ready Lift Leveling kit, EGR Blocker Plate, Firestone Airbags.
johnjohnson42 is offline
post #3 of 19 (permalink) Old 10-09-2012, 06:03 PM Thread Starter
Is AC Delco G61 the right glow plug for my truck and what is the torque value for the install . Thank you in advance for your help.
Duistruck
-Body Type: TK25743
-VIN: D97F13xxxx
post #4 of 19 (permalink) Old 10-09-2012, 07:06 PM
I can't remember the part # but I think I got the AC Delco brand... it was whatever Autozone had in stock... they were about $19 each. As far as the torque value, can't help you there. Don't have a torque wrench, so I just tightened them up firm... no issues.... yet.
post #5 of 19 (permalink) Old 10-12-2012, 06:40 PM Thread Starter
My connector was badly corroded and barely attached. Replaced my glow plug but need to attach a new connector. The nut did not come with the new glow plug and the old one was rusted too badly...made a pigtal with a new butt joint to attach to existing red wire. Where do I get the wee nut. Guessing I now have to disconnect the batteries to attach the pigtail correct? The remaining plugs are not throwing codes but the nuts are well rusted...need advice...leave them or replace. I'm worried because there isn't much left of the nut to get the 8mm on. Any advice please?
Duistruck
-Body Type: TK25743
-VIN: D97F13xxxx
post #6 of 19 (permalink) Old 10-12-2012, 06:44 PM
bubblebutt's Avatar
No power on pigtail until truck commands them on so if key out you have no problem, then u gotta clear codes after, about the others I would leave them till they give u a problem, or if u can't sleep at night do all of em,
2008 GMC Dually LMM
6" lift 285/75R17 "E" TOYO M/T
Banks intake/DPFdelete with MBRP exhaust
PPE Hot Race tuner / TransGo Jr. / Pillar gauges
JVC - DVD/Nav system & Back up camera/2500w inverter/ 55w reverse lamps/Amber strobe lights X4 corners
front hidden hitch/rear hitch/turn over ball 5th wheel hitch/custom grille
DRW # 101
bubblebutt is offline
post #7 of 19 (permalink) Old 10-12-2012, 06:57 PM
sayoda's Avatar
I got the tiny nuts at a hardware store. I think 5mm. They are also the same some RC car lug nuts , if you're into RC.
sayoda is offline
post #8 of 19 (permalink) Old 10-13-2012, 10:39 AM Thread Starter
Thanks folks...just came back from home depot and got the nuts but they don't turn past one revolution. I bought 8/32s...are the threads on the ac Delco different Thread?
Anyone know? Would you guys consider stainless steel nuts and washers?
Duistruck
-Body Type: TK25743
-VIN: D97F13xxxx
post #9 of 19 (permalink) Old 10-13-2012, 10:48 AM
sayoda's Avatar
they r metric nuts, 8/32 won't work
sayoda is offline
post #10 of 19 (permalink) Old 10-13-2012, 10:53 AM
sayoda's Avatar
and i'm also positive that home depot doesn't carry them, you are going to have to hit up an actual hardware store (something like Ace or Rocky's)... hope that helps!
sayoda is offline
