Engine code P0402 - Chevy and GMC Duramax Diesel Forum
post #1 of 26 (permalink) Old 11-09-2012, 02:16 PM Thread Starter
Engine code P0402
Pulled codes after check engine light has come on. Cleared code numerous times and still returns. Code says excessive EGR flow. Anyone have this issue with an easy solution. Some guys say EGR will be plugged up with carbon, others say mass air flow sensor. Just wanted to get someones opinion that has had this trouble or know the issue before spending some cash. Truck only has 79000kms.
2007 Silverado Classic 2500 4x4 LBZ
EvancLBZ is offline
post #2 of 26 (permalink) Old 11-09-2012, 02:32 PM
blunova's Avatar
I had that code when i went to after market af, put a blocker plate[egr] cleared the code did not come back on, now my egr is shut down with the efi live
2015 Gmc slt loaded, cognito ucas, keys bilstein 5100s,nitto dura grapplers 275-60-20,sonoma red metalic,coca dune leather, gm tri fold toneau cover,factory spray in liner,zone steering stabilizer
1969 ss nova back halved 604 ci big chief, rossler 400,8.42 on motor
blunova is offline
post #3 of 26 (permalink) Old 11-10-2012, 08:30 PM Thread Starter
Truck is completly stock, even the air filter. Probably sounds like the egr has to come off and be cleaned al least i guess. I bought a new ac delco air filter and im gonna put it in and clean the mass air flow sensor when i get a min of spare time. Hoping this cheap easy fix might do it.
EvancLBZ is offline
post #4 of 26 (permalink) Old 11-12-2012, 09:53 PM
Pearseam's Avatar
EvancLBZ, Had the same problem, Pulled the EGR out and cleaned it 4 weeks ago. Fun times It was about 90% blocked. This was my first time doing it at 92000 miles. Suggest while you have the EGR out just replace the EGR Solenoid (motor). Even after cleaning the EGR I was still getting the P0402 code. I even tested the motor for operation when I had the EGR out, it worked but I was still throwing the code. I just replaced the motor this weekend, hopefully that will be the end of it. Before pulling the EGR have at least 3 cans of cleaner I used B-12 throttle cleaner it works great. Good luck.
07 Sierra 2500HD, LBZ, CC, SWB, 45 Gal Fuel Tank by Transfer Flow. No Mod's
Pearseam is offline
post #5 of 26 (permalink) Old 11-15-2012, 11:37 AM
Dark Cloud's Avatar
I had this issue with after market cold air intake and I asked the same question about a year ago. I got back from someone that some of them did throw the code with stock intake so they came out with a calibration update (dealer update code fix). I asked what the code was and he did not know but he ran a repair shop and it sounded like good info. I would try the other suggestions first but keep this in your back pocket.
2006 Chevy Silverado LT 2500HD, LBZ, CCSB, 4x4.
Add ons: Truxedo, TransGoJr, Ranch Hand Legend Front Bumper, Tow Mirrors, Xtreme Bed Liner, Recon Cab Lights, Bluetooth ODB II data thru Android Phone.
Mods: Blue LED's in dash and all dash controls.
Dark Cloud is offline
post #6 of 26 (permalink) Old 11-15-2012, 02:07 PM Thread Starter
Checked out code on identifix and out of 11 confirmed fixes, 7 of them were dirty mass air flow sensors, a couple were bad egr motors and one was software and the mass air flow sensor. Cleaned the mass air flow sensor this morning and threw in a new air filter. Gonna try this first. Thanks for all the info.
EvancLBZ is offline
post #7 of 26 (permalink) Old 11-16-2012, 11:57 AM
eluebke's Avatar
I have been having this problem also since it started getting cold here. Once the temp dropped down into the 40's and 50's my engine light would come on just driving down the road at a steady speed. I can not notice any difference with the way the truck performed. I scanned it with the same P0402 code. My only problem is a few days later the light will go out by itself, only to come on again a few days later, sometimes it will be 2 weeks of driving before it comes back on. But it always comes on driving at a steady speed. I just had the light come back on yesterday for the 5th time in the last 7 weeks. For right now I will just keep driving the truck and see how long it takes to shut off again. Is this the same experience others are having? Or does the light come on and never go off until you clear the code yourself?
Thanks
Eric
eluebke is offline
post #8 of 26 (permalink) Old 11-17-2012, 08:42 AM Thread Starter
The light comes on and stays until its cleared on my truck. Even after I clear it it might come back in ten minutes or a week. It also seemed to come on when the temp got low as well. Worked excellent all spring, summer and fall this year. After I cleaned the mass air flow sensor, the light hasn't come back yet. Hoping it cured.
EvancLBZ is offline
post #9 of 26 (permalink) Old 11-17-2012, 08:42 PM
Pearseam's Avatar
eluebke, from my experience the CEL light comes and goes. Determined by when you start the truck and if the egr work properly or not. After replacing the egr motor last weekend I have not had a CEL come on at all this week. I'm saying its fixed. Usually I would have got the light by now, once a week off and then on. This weekend project was replacing the Lower Trans cooler line, not too bad of a job.
Pearseam is offline
post #10 of 26 (permalink) Old 11-19-2012, 08:37 AM
eluebke's Avatar
My light has not gone back out since I posted. I think I may try a new air filter and clean the mass air flow sensor. This seems to be the easiest fix to try first. If this doesn't work, how hard was it to get at the egr itself to try to clean it and change the motor for it? I'm really getting sick of looking at the orange engine light on my dash.
eluebke is offline
