Weak batteries??? - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 12-01-2012, 10:30 AM Thread Starter
Send a message via AIM to 04LB7
Weak batteries???
So yesterday I use my truck for work all day long with no problems. It was even 27 degrees in the morning and it started up just fine. Get home at the end of the day and park it, come back out to it after it sat for 5 hours or so and all it does is click and flicker the lights when I try and start it. Put a tester on the batteries and it says both are weak!!? How in the hell does two batteries go weak just sitting in my driveway after I've used the truck all day for work?? Nothing was left on because I have nothing in there to even leave on. Only thing I can think of is that the passenger side battery went bad and drained both of them down. I checked connections on both batteries and both are tight. I'm clueless here as to what happened here. Hopefully someone can chime in and shed some light on this. Also if anyone can let me know if replacing the batteries will erase the tune? I wouldn't think it would even hurt the tune, but I'd rather ask to be safe.
2006 Chevy 3500 HD Crew Cab dually.
Straight pipe MBRP 4" exhaust w/3" dp
PPE level 3
PPE air box mod
Stock tranny (for now)
Boost & Pyro pillar gauges
04LB7 is offline
post #2 of 6 (permalink) Old 12-01-2012, 10:35 AM
This space for rent!
Koho's Avatar
Had that very thing happen to mine. Was working all day came back out and did as you described. I threw the battery charger on it, ran it for a bit- came back out and it was dead again. Ended up going down to the dealer and bought 2 new batteries for it. My truck is at 70K thought that was pretty decent battery life as those where the ones from the factory.
05 LT 2500 CCSB 4x4 LLY
11 Harley Road King Classic "Screamin Eagle"
12 F350 King Ranch 6.7l PS
Of course all kinds of other stupid "Sh*t"
------ Yes Koho is a fish, but atleast I don't have Walleye vision ---------
Koho is offline
post #3 of 6 (permalink) Old 12-01-2012, 10:37 AM
bubblebutt's Avatar
Do batteries in pairs , and no won't erase the tunes,
2008 GMC Dually LMM
6" lift 285/75R17 "E" TOYO M/T
Banks intake/DPFdelete with MBRP exhaust
PPE Hot Race tuner / TransGo Jr. / Pillar gauges
JVC - DVD/Nav system & Back up camera/2500w inverter/ 55w reverse lamps/Amber strobe lights X4 corners
front hidden hitch/rear hitch/turn over ball 5th wheel hitch/custom grille
DRW # 101
bubblebutt is offline
post #4 of 6 (permalink) Old 12-01-2012, 11:37 AM
LHN...We ARE the Joneses
Originally Posted by 04LB7 View Post
…How in the hell does two batteries go weak just sitting in my driveway after I've used the truck all day for work??
Vibration/concussion during the work day finally did in the cell(s) on one battery, and then parking at rest for a period of time was enough for the bad one to drain down the 2nd for a no-start.
More than likely a single bad battery in the pair had a failing cell previously, but the 2nd good one remained strong enough to offset the drain and go unnoticed, which can weaken it over time.
At the end of your work day, the decaying set reached it’s limit after the 5 hrs at rest.
If available fund$ are an issue and you need more time, pull both and charge to determine the single shorted one of the pair.
Replace only the single weakened one of the pair, and cruise on. If in a colder climate, put a timer on your block heater for 1-2 hrs before the morning start is needed, to help the battery along buy reducing the glow plug drain on it.
Hook'em_Horns! is online now
post #5 of 6 (permalink) Old 12-01-2012, 12:30 PM Thread Starter
Thanks for the quick replies guys.
Ended up buying two batteries and its good to go.
PPE level 3
PPE air box mod
04LB7 is offline
post #6 of 6 (permalink) Old 12-01-2012, 01:30 PM
rms
rms's Avatar
What batteries did you get?
I replace my originals with Optimas in July of '09 (at 70k).
Now at 155k. I'll probably be replacing them in the next few months or so.
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/70/17 Michelin AT's on H2's - 8' Bedslide
Amp Steps - short KYB's - Fumoto
The Arizona Diesel Club
rms is offline
