LBZ timing / injector rattle on spool up - Chevy and GMC Duramax Diesel Forum
post #1 of 41 (permalink) Old 12-03-2012, 08:34 PM Thread Starter
I have a 2006 LBZ and it is tuned with efi live by idaho rob, when I get on it there is a loud timing/injector rattle while it is spooling, it does it on all of the tunes but is more noticeable on the hotter tunes. Does this mean my injectors are going bad? Truck has 200k miles. Thanks.
boosted4life is offline
post #2 of 41 (permalink) Old 12-03-2012, 08:36 PM
ATPTRUCKS
sickdiesel's Avatar
What are the mods of the truck? Has the truck always done it or just started to?
2017 GMC Denali CC/LB L5P
06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
07 Chevy lbz 4x4 Caged and built 10.42@134 SOLD
Special thanks to: Mike L, Gtrippin, IdahoRob, Dmaxstore, HSP, ISSPRO, Yukon, Airdog
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline
post #3 of 41 (permalink) Old 12-03-2012, 08:44 PM
SickLL7Crenshaw's Avatar
fuel rattle maybe? doubt its timimg rattle with robs tunes.
05' LLY CC/SB 12.41 @109.9 119k
Blake
SDP Twinz, 40% overs, EFILive by me, Stage V trans, BT lock up box
4'' Exhaust, Airdog, Traction Bars, Built Front End,
Big Thanks to Henry and Scott
01' LB7 EC/SB 13.5@97 230k
EFILive by me, Grade C HG, ARP studs,
4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans
SickLL7Crenshaw is offline
post #4 of 41 (permalink) Old 12-03-2012, 08:44 PM Thread Starter
intake, 5" exhaust, uppipes, downpipe, air dog 2, rail plug, ported rail fitting, built trans, egr delete, 4094vvt, efi live by rob. Truck has always done it with these tunes but i havent ever ran any other tunes since the turbo.
post #5 of 41 (permalink) Old 12-03-2012, 08:50 PM Thread Starter
also truck doesnt make any more power on tune 5 vs 4. 4 makes the same power with less smoke and lower egts. But I am at high elevation, and dont get me wrong the truck runs like a raped ape, but 5 just smokes like a coal train. Just trying to figure out if my injectors are bad?
post #6 of 41 (permalink) Old 12-03-2012, 09:15 PM
TakeEm's Avatar
Subd
Caleb
2011 Denali LML
Wehrli Emissions Compliant 475/stock kit, Wehrli Dual CP3 Kit, Merchant Auto Trans, Fass Pump
Tuned by Duramaxtuner
Sold 7/2015: Twinned 07 LBZ
TakeEm is offline
post #7 of 41 (permalink) Old 12-03-2012, 10:32 PM
chevy71pickupman's Avatar
It's not timing rattle it is probably a fuel rattle. It is very hard to get timing rattle in a diesel. I had the same problem with a set of my tunes and I never did figure out what was causing it.
Adam
BIG THANKS TO ROB CODDENS AND DUSTIN GULLETT AT ATPTRUCKS FOR ALL THERE HELP
WWW.ATPTRUCKS.COM
www.alligatorperformance.com
DMAXSTORE.COM
chevy71pickupman is offline
post #8 of 41 (permalink) Old 12-04-2012, 06:32 AM
ATPTRUCKS
sickdiesel's Avatar
Call me tomorrow and we can log the truck. Have you tried contacting us before or was this the first time by making the thread?
post #9 of 41 (permalink) Old 12-04-2012, 10:47 AM
KB3MMX's Avatar
Timing rattle IS caused by the fuel in a diesel.
Too advanced initial timing can cause this or the effect from ramping the pressure in too fast causing a increase in the dynamic timing of the motor.
We could also get into transiant timing as well.....again, a timing setting problem based on transient load.
Timing Rattle can also be worsened from poor quality, low cetane fuel that doesn't burn as smoothly. This resulting in pressure spikes in the cylinder..more of a explosion than a controlled burn.
Anyhow, I really doubt it's advanced timing in Rob's tune, he's VERY VERY consevative on timing...but there could be a error.
Usually other issues like EGT problems show up from that, especially on bigger tunes.
Go back to Rob and give him the chance work it out for you..
OP, It's always good to try contacting the tuner first...Dustin will get you squared away, hopefully at no cost.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #10 of 41 (permalink) Old 12-04-2012, 10:54 AM
Banned
too much timing down low
Hondarider552 is offline
