truck died and wont start - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 12-11-2012, 12:39 PM Thread Starter
Maxwell.Riddle's Avatar
this is what ive done lately. changed oil and installed cat adapter and filer 4 days ago. yesterday had a double din stereo installed. ran great yesterday and all today. started it to go to work and started fine. ran for about 15 seconds and died. tried to restart and turns over strong, but thats it. HELP! i need to get to work, and im supposed to drive all the way to california in 3 days!
2006 CCSB LLZ 4x4
Upgrades:EFI Live from ATP Trucks w/ DSP5 Switch // EGR Blocked // PCV Reroute // 4'' Straight Pipe Exhaust
Interior:Tan Leather Interior // LT Package // AppRadio Double Din // Flip Down TV/DVD Player
Exterior:17'' Walker Evans Racing Rims // 305/65/17 Procomp Xtreme A/T Tires // Roll-Back Tonneau Cover // B&W Hidden Gooseneck Hitch
Wish List:AirDog II // 3'' Down Pipe // 5'' Exhaust // Twins // ZF6 Swap // SAS w/ 4'' Lift
Maxwell.Riddle is offline
post #2 of 11 (permalink) Old 12-11-2012, 01:11 PM
03_dmaxhd's Avatar
Check around your filter, make sure nothing got loose to where you are sucking air. Also did it throw any codes?
2007 Crew Cab 4x4
-EFI from ATP on the way
-MBRP 4" Turbo back
03_dmaxhd is offline
post #3 of 11 (permalink) Old 12-11-2012, 01:20 PM Thread Starter
no codes, checked fuel filter, dont see nothin
2006 CCSB LLZ 4x4
post #4 of 11 (permalink) Old 12-11-2012, 01:30 PM Thread Starter
i take off the fuel filter head bleed screw and make sur ist primed. put the screw back of and it is soft....anything
2006 CCSB LLZ 4x4
post #5 of 11 (permalink) Old 12-11-2012, 01:40 PM
03_dmaxhd's Avatar
If you take the screw out, pump the bulb till diesel a little diesel comes out, screw the screw back in and pump the bulb till it gets hard to keep pumping....If it never gets to where its hard to pump my guess would be your leaking diesel out somewhere....
2007 Crew Cab 4x4
-MBRP 4" Turbo back
post #6 of 11 (permalink) Old 12-11-2012, 01:41 PM Thread Starter
fixed it, put on old fuel filter and it works now. ned to find out whats up with the cat adapter!
2006 CCSB LLZ 4x4
post #7 of 11 (permalink) Old 12-11-2012, 05:27 PM
Administrator
jc1843's Avatar
Moving to LBZ truck runs.
jc1843 is offline
post #8 of 11 (permalink) Old 12-11-2012, 05:30 PM
This space for rent!
Koho's Avatar
If it happens to be a new purchase from adp give them a call. There have been issues w/the new cat adapters that they sent out.
05 LT 2500 CCSB 4x4 LLY
11 Harley Road King Classic "Screamin Eagle"
12 F350 King Ranch 6.7l PS
Of course all kinds of other stupid "Sh*t"
------ Yes Koho is a fish, but atleast I don't have Walleye vision ---------
Koho is offline
post #9 of 11 (permalink) Old 12-11-2012, 06:03 PM
so you managed to run it on the cat filter for a day or so before this occurred? I wouldnt throw away the cat filter just yet. Put it back on. Make sure that you bleed the filter with the bleed screw. (Loosen, pump til you see diesel, tighten) make sure all connections are good and tight, see what happens.
If a diesel engine wont run, it's a fuel problem. (Ok...barring a rod sticking out of the block)
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline
post #10 of 11 (permalink) Old 12-11-2012, 06:22 PM Thread Starter
yea i found that out tonight. they are going to hook me up with one next week.
2006 CCSB LLZ 4x4
