Dead pedal - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 12-21-2012, 03:41 PM Thread Starter
Angry Dead pedal
When i get into throttle it loses all power for couple sec dpent do it sll the time.have 4to inch exhaust cat back, edge, afe dry filterand a screw in my fuel rail gor higher pressure
DuramaxKB is offline
post #2 of 11 (permalink) Old 12-21-2012, 03:47 PM
Hang it!...Fire!
TDIpowered's Avatar
In english?
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
post #3 of 11 (permalink) Old 12-21-2012, 03:48 PM
dirtymaxxx03's Avatar
Hahahaha wtf
2012 LML LTZ
Color Matched, PPEI, FASS, SDP, aFe
Build Thread--->>SC LML Build
dirtymaxxx03 is offline
post #4 of 11 (permalink) Old 12-21-2012, 03:55 PM
nmeyer414's Avatar
is that troll english or WTF!
say it again in english man!
NATE
06 LBZ, CC SB
52 gal titan
edge juice w/ attitude
http://real-man-truckworks-and-survi...p?action=forum
nmeyer414 is offline
post #5 of 11 (permalink) Old 12-21-2012, 03:56 PM Thread Starter
sorry phone ato spell check.When i get into throttle it loses all power for couple sec doesnt do it all the time. i have 4 inch exhaust cat back, edge programer, afe dry filter and a screw in my fuel rail for higher pressure. its starting to do it more often replaced fuel filter 2000 miles ago
post #6 of 11 (permalink) Old 12-21-2012, 04:04 PM
boostnlb7's Avatar
i can read that.. LOL when it loses power for a couple seconds does it comes right back to life if u keep in the throttle?
Eddie "boost master"
03 lb7 ccsb 4x4- HD hood and grille- inch lower than stock 20" mkw's 305/50/20 cooper zeons
Now all glowshift gauges- traction bars- DHD stainless DP-4" MBRP- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 from tony burkhard and danville performance
suncoast stage 4 trans, goerend "ML style" triple disc billet converter
*Passin' 35psi on stock IHI with 290k on it* #edit#- freshly rebuilt with a drop in wetzel wheel and powder coated compressor housing with an RPI custom intake horn
boostnlb7 is offline
post #7 of 11 (permalink) Old 12-21-2012, 04:05 PM
When mine did that I ended up having to replace the injectors.
2003 2500HD Crew Cab 4x4, S&B Dry CAI, AirDog 100, Sinister Diesel Sump, MBRP 4" Downpipe back exhaust, Edge CTS, EFI Tuning by Idaho Rob, Iron Cross winch bumper, Badlands 12K winch, Alpine GPS, Roll n Lock, 285/70/17 Cooper STT's on H2's.
Mpope is offline
post #8 of 11 (permalink) Old 12-21-2012, 04:07 PM
Coffee addict
ty_LBZ's Avatar
Tighten the screw in your fuel rail, should solve your problem
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa muffler. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts. Curt class 5 hitch.
10/30/14- cracked piston
03/14/15-Back from the dead
ty_LBZ is offline
post #9 of 11 (permalink) Old 12-21-2012, 04:10 PM Thread Starter
yes it comes right back
4inch cat back
afe filter
post #10 of 11 (permalink) Old 12-21-2012, 04:11 PM Thread Starter
it started on my way back from ca. i was towing my trailer
4inch cat back
afe filter
