Bleed Screw Thread size? - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 12-29-2012, 05:42 PM Thread Starter
I am wanting to make up a pressure gage with a bleed screw....anybody know the thread size of the bleed screw offhand?
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline
post #2 of 5 (permalink) Old 12-29-2012, 06:06 PM
05Rattler's Avatar
Not sure of the size but I got my adapter fm Merchant......Only difference now is I have a 0-15 psi gauge there instead. Added the bleeder screw on the fitting so I can still bleed it off if I have to. Works great.
2005 LLY Chevrolet 2500HD
4 Door Crew, LT, BD Primary Fuel Filter (Cat 1R-0749),
AMSOIL Engine Oil Bypass, Raptor RP-100 Lift Pump
Dieselsite Bypass Coolant Filter
AFE Mouthpiece, Firestone Air Ride,
Undercover Tonneau Cover, Bed Rug,
223,000 kms. and counting
05Rattler is offline
post #3 of 5 (permalink) Old 12-29-2012, 06:10 PM
05Rattler's Avatar
Just a thought.... Are you going to add a lift pump? If not you will have to use a vacuum gauge to measure the draw from the Cp3.
With my set up it shows the pressure from my lift pump thru the OEM filter and onwards. Without the pump it is a vacuum all the way to the Cp3
post #4 of 5 (permalink) Old 01-31-2013, 05:33 PM Thread Starter
understand completely: It's vacuum now.....but I am installing a Fass 150 real soon
CapnDean is offline
post #5 of 5 (permalink) Old 01-31-2013, 05:42 PM
nsolimini's Avatar
10mmx1.5
2008 LMM CCSB LTZ 554HP 1015Torque
Sold2007 LBZ 2500HD Crewcab 4x4, EFI Live DSP5, TransGo Jr, Airdog II 165, MBRP 3" Downpipe, AFE intake, 4inch RBP turboback straight piped exhaust, egr blocked, PCV Rerouted, tie rods sleeved, 20inch Fuel Hostage, 305/55R20 procomp extreme A/t
SOLD2003 2500HD Ext cab LB7 4x4, EFI Live DSP5, PPE Boost Valve, Airdog 150, AEM HD intake, MBRP 5inch straight pipe, 20 inch eagle alloy 097, 33inch federal couragia mt
nsolimini is offline
