2006 Duramax 3/4 Ton SUV Project - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 67 (permalink) Old 03-27-2013, 06:52 PM Thread Starter
E34M30TT's Avatar
I just picked up a 2006 DMax 4X4. I'm intending to swap the powertrain into a 3/4 ton Suburban or Yukon XL.
I believe I'll need to source a new radiator, charge cooler, fan, and core support to swap into the 3/4 ton SUV.
I figured this would be a good place to post on this, gather some opinions and advice from any who have done it before.
I know DuraBurb out of Florida is the expert in this, I hope to tap them as a resource.
I don't have a Suburban yet, but I know I need to look for a late GMT800 style 3/4 ton for the easiest swap of this LBZ. (2003-2006) Does anyone know the production date in which they went to the chassis harness that plays nice with the LBZ?
Anyone have an '03-'06 Suburban/Yukon XL with a blown engine but clean body and interior for cheap?
I also like the look of the facelifted Silverado front end on the SUVs, much like this picture. This is a non HD front end, but you get the picture.
Thanks for any advice and thoughts!
https://picasaweb.google.com/1046619...LP3hvq9-8bmpwE
E34M30TT is offline
post #2 of 67 (permalink) Old 03-27-2013, 07:44 PM
Viergutze's Avatar
First off, welcome to the forum second that's a cool project and look into the 05-06 front end with the color headlight separator piece, I think it looks better. Good luck
Sent from AutoGuide.com App
2004 Chevy Silverado 2500HD LS 6.0L SOLD!!!!
2009 Silverado 2500HD LTZ CCSB 4x4
Industrial Injection Twins Setup 55psi
Built Transmission by Ultimate Transmissions
Opie Fuel Pump
EFI live Tuned Personally by Idaho ROB
Rough Country 8" lift
37"x13.5" Toyo Open Country
Eaton Front E-Locker
Viergutze is offline
post #3 of 67 (permalink) Old 03-27-2013, 07:54 PM Thread Starter
E34M30TT's Avatar
Thanks!
Can you post a picture of that front end you are talking about? I'm not sure I've ever seen what you are describing.
Also looks like my pictures didn't load correctly into my post. The picasa album link at the bottom shows a few pictures.
E34M30TT is offline
post #4 of 67 (permalink) Old 03-28-2013, 03:37 AM
silver_lml's Avatar
If you look up duraburb, its a company that puts duramaxs in yukons/suburbans. Im sure they can help you out.
Tyler
2013 GMC 2500HD SLT CC/SB Z71 4x4 __Kory Willis tunes, Flo-pro 5" no muffler, Egde Insight CTS2, B&W turnover ball, 275/65/20 Toyo AT2s on stock wheels, factory nerfs(missing my 3 steps) RDS 60gal fuel tank/toolbox combo,
Originally Posted by JOKER View Post
You can never have too much tire, only too much fender.
silver_lml is offline
post #5 of 67 (permalink) Old 03-28-2013, 11:58 AM Thread Starter
E34M30TT's Avatar
Originally Posted by E34M30TT View Post
Thanks!
Like this one? This is the standard front end on the '05 and '06 HD Chevys. Granted, this one has had some paint work done to it.
E34M30TT is offline
post #6 of 67 (permalink) Old 03-28-2013, 05:41 PM
Tony323's Avatar
Best of luck to you. Ive always liked the idea. Afterall, the only powerstroke id ever own would be an excursion
Tony Lewis
06 ccsb lbz 4x4
Kory Willis dsp5
Big Dipper w/ml converter
Kryptonite steering, airdog165
rerouted,deleted,debadged,plugged, bt lockup
eaton front locker
12.67@104
Tony323 is offline
post #7 of 67 (permalink) Old 03-29-2013, 08:14 AM
Viergutze's Avatar
Exactly thanks
Opie Fuel Pump
post #8 of 67 (permalink) Old 04-03-2013, 09:32 AM Thread Starter
E34M30TT's Avatar
Got the truck delivered yesterday, started digging into what I have to work with.
Checked RPO codes, 3.73 axles, rear LSD, engine block heater. Fairly standard truck.
Anyone have any ideas what the, "Northwest Edition" got me? Probably just stickers?
Still on the hunt for a clean 3/4 ton '03 - '06 Yukon XL or Suburban!
E34M30TT is offline
post #9 of 67 (permalink) Old 04-03-2013, 11:00 AM
Coffee addict
ty_LBZ's Avatar
Build thread!! Build thread!! Build thread!! Nannere
Do a build thread with pics. Wanting to do this myself, I would get one from Duraburb, but that's way too expensive for me. Building is the only option for me.
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa muffler. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts. Curt class 5 hitch.
10/30/14- cracked piston
03/14/15-Back from the dead
ty_LBZ is offline
post #10 of 67 (permalink) Old 04-03-2013, 11:17 AM
lddrew's Avatar
northwest edition is just a sticker. best of luck with your project! and welcome to the DF!
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline
