Blue smoke - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 03-24-2009, 11:14 PM Thread Starter
drew18's Avatar
Blue smoke
Hey guys, when i put my 5 inch straight pipe on my truck it started blowing blue smoke at idle, it does this when it is hot or cold and my truck only has 20,000 miles what do you guys think is causing it to blow blue smoke? does my truck need to be reprogrammed or something?
thanks, drew
2006 GMC 2500 SLT LBZ 4X4 CC SB, MBRP 5" straight pipe, 6" RCD lift kit, 35" Kumho AT's, 20X10 Jesse James rims
drew18 is offline
post #2 of 12 (permalink) Old 03-24-2009, 11:22 PM
Duramax-LML's Avatar
brand new pipe...just blowin some oil and watnot out thats on the piping its comp. normal u'll see that with a brand new exhaust
Name: Jake Age:26 INSTAGRAM: @jakethomaspnw
2013 Duramax LML CCSB LTZ My Build Thread
SPORTSMAN CP3/ S369SXE/ 30% OVER EXXERGY INJECTORS, FASS 150, diamond eye 5" TB,6" Fabtech Lift no bolts, 35inch Toyo M/T, 20x12 Fuel Octanes,ISSPRO EV2 GM MATCH, BOSS grill,Fusion front and Iron Cross rear, Pioneer In dash, subs, ARB twin air compressor, Cognito UCAs
Duramax-LML is offline
post #3 of 12 (permalink) Old 03-24-2009, 11:27 PM Thread Starter
drew18's Avatar
I put the exhaust on around 1000 miles ago could it take that long to burn the oil off the pipe?
drew18 is offline
post #4 of 12 (permalink) Old 03-24-2009, 11:33 PM
hmmm I would say that could be pushin it mine stuck around for about 1 full tank of diesel and thats bout it...It flared up another time about 600mi in then I didnt see it again
last fuel filter change?? I couldnt imagine it beeing the injectors...and it doesnt look like a timing issue cuz its stock tune right?
post #5 of 12 (permalink) Old 03-24-2009, 11:36 PM Thread Starter
drew18's Avatar
The only mods it has is a cold air intake, straight pipe and i have the turbo resonator plugged, other then that it is completely stock, and my driver display thing says my fuel filter has 63% life left.
drew18 is offline
post #6 of 12 (permalink) Old 03-24-2009, 11:46 PM
havent had this prob...any1 else got anything...BUMP
post #7 of 12 (permalink) Old 03-25-2009, 05:48 AM
AlligatorPerformance's Avatar
If your worried about it, take it to the dealer and have your balance rates read. Otherwise, my truck has done that since new, (not blue smoke, but a gray haze) and my balance rates are perfect. You might not have noticed it as much, but since you removed the cat, it's expelling the particulate that would have normally been trapped by the converter.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
Shop Location - 4470 W. Seltice Way, Ste. E - Post Falls, ID 83854
DPF Delete PKG's - Gauge Packages - PRICE BEAT GUARANTEE - Blocker Plates
AlligatorPerformance is offline
post #8 of 12 (permalink) Old 03-25-2009, 07:18 AM
midieselguy's Avatar
I agree with what he said. Mine has done the same thing since I put my exhaust on. More blue when it's cold out, can't say I've seen smoke idling warm.
2004.5 LLY, X-Cab, short-bed, Allison Trans, 4" MBRP Turbo-back, no cat, KB's IOH kit, EGR block plate, no finger stick, deep trans pan, MB Razor 16x8 with BFG AT 285's
midieselguy is offline
post #9 of 12 (permalink) Old 03-25-2009, 08:09 AM
05greendmax's Avatar
mine smokes real bad blue smoke when its cold
2005 ccsb hunter green
rip old motor
(fully stock)
motor going in
huge thanks to Dustin and robb at (ATP)
could not have donr this with out your help
hope this new motor holds 500hp this time
05greendmax is offline
post #10 of 12 (permalink) Old 04-06-2009, 05:21 AM
deerenwr14's Avatar
Send a message via AIM to deerenwr14
blue
mine will smoke a little in the morning when i start it.
2007 GMC Sierra classic 2500 HD
Crew cab short bed
4" down pipe back MBRP exhaust
AFE stage 2 intake
Superchips set to tow performance
13% tint and vent guards
deerenwr14 is offline
