fuel pressure? - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 06-29-2009, 06:53 PM Thread Starter
fuel pressure?
what is the fuel pressure suppose to be stock? say at idle an WOT? thanks.
2009 GMC ECSB 4x4 Duramax-Black-51k miles-Sunroof-275-70-17 BFG KO2-Bed cover-Airbags
sofakingbad is offline
post #2 of 16 (permalink) Old 06-29-2009, 07:21 PM
maxxedout's Avatar
well if u dont have a lift pump it wont be pressure it will be a vacaum reading
Truck 1-2009 Chevy 2500HD CC SB 4X4 Black All Stock For Now
Soon To Come DPF CAT And Muff Delete Tuning VIA EFI Live SC IV
Truck 2-2002 GMC 2500HD CC SB 4X4 Summit White Autometer Boost & EGT AirDog 150 Custom CAI(built by me) PPE Boost Valve Black 6'' Single Stack Rough Country Leveling Kit 265/75/16 Goodyear AT/S
EFI LIVE TUNED BY IDAHO ROB
:rockin
maxxedout is offline
post #3 of 16 (permalink) Old 06-29-2009, 07:35 PM Thread Starter
a friend is wanting to get a fuel pressure gauge....an he asked me what it should be reading an i said i have no idea.....so is a fuel pressure gauge no nessary with out an aftermarket lift pump?
post #4 of 16 (permalink) Old 06-29-2009, 07:39 PM
Banned
WOT a lb7 lly will be 23,300psi
WOT a lbz lmm will be 26,600psi
At idle they are all around 5k i believe.
That is rail pressure, you wont get any fuel line pressure with out a lift pump.
A lift pump is good around 10-12psi at idle. Anymore than 14-16psi and it will cause the motor to lope=no good. At WOT you want atleast 4-6psi IMO or atleast a positive number.
With a heavy fueled 500hp tune you can drain the rails down to 10,000psi and the motor will spit and sputter. A lift pump will help maintain 21,000-26,000psi depending on your tune.
nwtdiesel is offline
post #5 of 16 (permalink) Old 06-29-2009, 08:03 PM
maxxedout's Avatar
you got it no need for a gauge without a lift pump. unless he is wanting to know his rail pressure but there is really no need for that if he is stock
:rockin
post #6 of 16 (permalink) Old 06-29-2009, 08:13 PM Thread Starter
sweet thanks.....
post #7 of 16 (permalink) Old 06-29-2009, 08:13 PM Thread Starter
makes since.....he is just wanting to fill his gauge pod so that is why he is wanting a fuel pressure/rail pressure gauge
thanks
post #8 of 16 (permalink) Old 06-29-2009, 08:18 PM
blackdeath's Avatar
high pressure diesel in the cab, humm id pick a diff temp gauge first
blackdeath is offline
post #9 of 16 (permalink) Old 06-29-2009, 08:26 PM
Banned
You can get 15psi to 100psi electrical fuel press gauge from autometer.....
That would be perfect for his lift pump application.
post #10 of 16 (permalink) Old 06-29-2009, 08:28 PM
blackdeath's Avatar
no i mean rail pressure . lift pressure sure
