egt temps? - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 02-05-2008, 09:50 AM Thread Starter
trashygasman's Avatar
egt temps?
where should I set my max egt at? I have it set at 1250, but if I get on it very hard it hits it and defuels on me. Should I have my pyro in my exhaust manifold instead of the turbo downpipe?
Kyle
2006 Silverado LBZ, CC/SB 4x4
EFILive by JoshH
S&B
MBRP
Transgo Jr.
AirDog 150
ProFab EGR Delete & Downpipe
2015 F-350 SRW 6.7L CC/LB FX4 4x4 (company truck)
trashygasman is online now
post #2 of 11 (permalink) Old 02-05-2008, 10:03 AM
Yes, it will have a different temperature. Also as for setting it, I have been told that 1350, the heads on a Duramax start to melt.
2014 Duramax/Ally 3500 CC 4X4, all stock!
USN-MA2 is offline
post #3 of 11 (permalink) Old 02-05-2008, 10:22 AM
Hi, I'm Earth. Have we met?
05_LLY's Avatar
Having it post turbo, towing i would not go over 1100 deg or 1300 if it was pre turbo. If you are just messing around on the street and running it hard in short burst, set it to max for short burst you wont hurt anything, myself and others have easily pegd 1600 and 1800 deg gauges while sled pulling or drag racing. Egts on these trucks run over 1250 degs stock!
Hot rodding duramax trucks since 2004
05_LLY is offline
post #4 of 11 (permalink) Old 02-05-2008, 11:07 AM
Diesel Addict
my egt probe is on the driveside exhaust manifold and i can easily see 1200-1300* on a hill with a trailer and the most i have seen was 1760* but on sort bursts it won't hurt it but my pryro is before the turbo so after the turbo i wouldn't let it go above 1100-1200* max.
Project, Rogue Budget(Workstock Puller)
2006 GMC 2500HD, Stock Motor, EFILive by me, Billet 63 VVT, Motorsport Stroker CP3, 20% Nzls, ProFab Manis n Uppipes, BD IC, Hot Pipe IC, ProFab Y-Bridge, lots of other goodies
TYREBOYZ_DEMAXIN is offline
post #5 of 11 (permalink) Old 02-05-2008, 11:07 AM Thread Starter
ok, thanks. right now i'm just running around. during the summer i pull a 20' boat with it. so i'll turn it down while, i'm towing.
Kyle
EFILive by JoshH
S&B
MBRP
Transgo Jr.
AirDog 150
post #6 of 11 (permalink) Old 02-07-2008, 04:15 AM
Maxed 08's Avatar
What is the ideal place for a egt probe to be located?
Randy
2007 GMC Sierra 2500 HD Efilive by Idaho Rob w dsp5 switch, built trans with gmax 6 and 1056 TC, 150 lift pump, 4in dual exh, s&b intake,tie rod sleeves,DHD centerlink brace, 3in drop shackles, caltracs, pcv reroute,resonator pluged, egr blocker plate,autometer gauges,20x9 0 offset gear 726 wheels and 305/50/20 Toyo proxes st.
RIP 2008 Chevy 2500 HD 8.22 @ 82 1.71 60ft
Maxed 08 is offline
post #7 of 11 (permalink) Old 02-07-2008, 05:35 AM
custom8726's Avatar
Randy
Exhaust manifold, You can drill and tap your's or buy a BD exhaust manifold they come pre drilled for a EGT probe for the drivers side. If you drill your own, drill the passenger manifold there are some pics on kennedy diesel for placement.
2012 Denali H.Dů Cognito Lift, Fox shocks etc etc
05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., Deep pan, Fumoto valve, AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, LBZ mouth piece, COGNITO H.D. TIE RODS & BRACES.
EFI LIVE, DSP-5...... ATP TUNING, 40 over BD Injectors 4" T.C. lift, 35" Nitto graplers, Rancho 9000's
Built motor, "Big Twin's", Dual Fuelers
04 - LB7 Reg Cab (Current race truck project) youcrazyy
custom8726 is online now
post #8 of 11 (permalink) Old 02-07-2008, 05:51 AM
Diesel Addict
the most accurate place is the driveside manifold but it isn't the easiest place to get to.
post #9 of 11 (permalink) Old 02-08-2008, 12:24 PM
The manifold for sure is the safest place to tap. There can be as little as 50 degrees to as much as 600 degrees (depends on thottle position and load) difference in temps between the pre and post points. Measuring after the turbo is just guessing.
Bob Riley
DIESELSITE is offline
post #10 of 11 (permalink) Old 02-08-2008, 01:01 PM
BryanVilaubi's Avatar
Bob Riley
X2 Well said!!!
2003 GMC Sierra LB7
New motor in the works as we speak with lots of goodies!!!
BryanVilaubi is offline
