Help Code P0540 - Page 4 - Chevy and GMC Duramax Diesel Forum
 1Likes
post #31 of 43 (permalink) Old 05-13-2010, 11:29 AM
bwano's Avatar
2001 LB7 code P0540
Just replaced all injectors.
Service Engine light, remained on.
Won't pass smog in California due to P0540.
Where is the heater gizmo?
Maybe I blew the fuse, or forgot to reconnect wire, I do remember hitting intake w a hot live cable and getting a nice little arc on the intake.
Do I have to go to dealer to reset engine light and code?
John
bwanojohnny@sbcglobal.net
bwano is offline
post #32 of 43 (permalink) Old 05-13-2010, 11:32 AM
Quicker Then Brian!
RedBowTies88's Avatar
John
you can replace the heater with a plug then get the code turned off via efilive. its not really needed anyway
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #33 of 43 (permalink) Old 05-13-2010, 12:05 PM
bwano's Avatar
ok where is heater?
where is heater? what does it look like?
I'll check your website later.
Thanks
colonelbob likes this.
bwano is offline
post #34 of 43 (permalink) Old 05-16-2010, 03:34 PM
bwano's Avatar
Air Intake heater diagnose
Ok
175 amp fuse ok, under fuse block cover. had to remove fender brace.
No 12 volt to heater when engine cold. Well, 70 degrees ambient san diego.
Wait to start light does come on.
Is air intake not cold enough to switch on power?
Where to look next, Relays?
bwano is offline
post #35 of 43 (permalink) Old 05-17-2010, 02:48 PM
bwano's Avatar
P0540
Fuse ok.
No power to Battery side of Relay for AIH
Looks like when I removed Glow Plug control, put AIH power lead to ground post instead of Hot Batt post.
Will verify. Any one else done this?
bwano is offline
post #36 of 43 (permalink) Old 04-03-2012, 10:10 PM
titch--'s Avatar
Originally Posted by SHREDDER View Post
just replaced mine on a lb7. Check for 12 volts at the controller. Black box driver side valve cover right at the back near the fire wall. You can't miss the large power wire going to it. Pull up the rubber boot & check. If the fuse is shot something caused it to go. My controller went which caused the fuse to go I hope!! So far I'm good. fingers crossed LOL! fuse is 5 dollars.
I know this is a old thread but I just started getting this code and I thought I would ask here
Whats the name of this black controller box? I broke a chunk of this plastic box when I was installing my down pipe a while back, but never had a problem with it until I recently installed my new tunes. So Im thinking of changing it.
03 LB7 ECSB - BCI & horn - BMW - MBRP DP - MBRP 4" tb - PPE Boost valve - UDP adaptor with 1R-0750 - LBZ FPR - Shimmed FPRV - Raptor 100 - EFILive ATP - Autometer Boost/Pyro - Built Tranny - Firestone Level-Rites - MA TR sleeves - MOOG Idler/Pitman - H2's with 285/70/17 Duratracs -
titch-- is offline
post #37 of 43 (permalink) Old 04-04-2012, 05:40 PM
Intake Heater Relay Duramax LB7
2000 - 2003 Chevy GMC 6.6L Duramax LB7
Product # HTS107
Your Price: $407.40
[Read Reviews] [Write A Review] [Add to Wishlist]
Quantity:
Delphi Intake Heater Relay fits 2000 - 2003 Chevy GMC 6.6L Duramax LB7. Part # HTS107.rem
Donot buy from here!! I can't remember where I got mine but I only paid about 100$ Wow old thread!
2003 BLACK CC DUALLY LT
EDGE JUICE W/ ATTITUDE
PPE BOOST VALVE
SHREDDER is offline
post #38 of 43 (permalink) Old 04-04-2012, 08:39 PM
titch--'s Avatar
ok thanks for that
titch-- is offline
post #39 of 43 (permalink) Old 06-09-2012, 05:18 PM
this sounds like my problem,, how do you test the controler??
the fuse blows when i connect the pink wire at the iah relay block?
smurfdaddy is offline
post #40 of 43 (permalink) Old 06-10-2012, 04:59 AM
cuse diesels's Avatar
TITCH.... just have Rob eliminate the code.
06 cclb 3500 single lbz
cuse diesels is offline
