crank position sensor - Chevy and GMC Duramax Diesel Forum
post #1 of 13 (permalink) Old 02-02-2010, 07:36 AM Thread Starter
hi, new here and to the diesel world. just got an 07 2500 and have had it in the shop 2 times in past 4 weeks cause the crankshaft position sensor keeps going out. has anyone seen this before?
NYdiesel_nutz is offline
post #2 of 13 (permalink) Old 02-02-2010, 10:42 PM
Tow Master's Avatar
Welcome to the forum!
I heard of them go once but usually a new one will cure it. Maybe the dealer is cranking it down to tight? Or it could be a defective part. Post back if it goes out again.
Jason
Tow Master is offline
post #3 of 13 (permalink) Old 02-19-2010, 07:40 PM Thread Starter
so the sensor went agan today. ive had the truck 3 months and had it in the shop for this the same number of times. anyone know anything?!? its pissing me off now.
2007 2500hd LBZ LT 4x4 cclb
4" mbrp turbo back, more to come
post #4 of 13 (permalink) Old 02-19-2010, 07:57 PM
prick62's Avatar
Mine went out twice. First time they replaced it under warranty. The second time they could not findout why the truck would not start. They spent two days on it and it would not throw a code. It turned out my edge chip was the problem, they took it out and it started right up! We told them to throw the chip in the trash and it has not had a problem since!
VEHICLE: 2003 GMC Crew Cab Dually 3500, 69k miles, color matched grill/door handles, all emblems removed, billet grill, 18% tinted windows, custom wheels (UGLY), Autometer gauges
PERFORMANCE PARTS: Idaho Rob tuned EFI, K+N Intake, Magnaflow 4" Exhaust w/ 5" tip, Edge chip removed (JUNK-blew out crank sensor twice), 15w-40 Amsoil Synthetic, New Injectors @ 63.5k with 16 days to go on warranty :rockin
EXTERIOR ACCESSORIES: Lowered 6" Front-8" Rear, C-Notched, Axle Flipped, Transmission Cross Member Raised, Firestone compressor and air bags,Timbren 540 overloand springs, bullet proof steering tie rods, 3.73 Posi
MY STANDARDS ARE ALMOST AS LOW AS MY TRUCK!
prick62 is offline
post #5 of 13 (permalink) Old 02-19-2010, 08:07 PM Thread Starter
thats the thing, its stock. i think the mech is just to damn lazy to trace it and see wtf is really going on. luckily i still have the warranty.
post #6 of 13 (permalink) Old 02-23-2010, 07:25 AM Thread Starter
ok so dealership finally got it. there were a few wires that had chaffed thru and were shorting out the sensor. figures.
post #7 of 13 (permalink) Old 02-23-2010, 07:56 AM
cuse diesel's Avatar
good to hear should hook up in dewitt daily
cuse diesel
2006 crew cab, long box, lt 3500 single (LBZ) 4x4:
4" mbrp with 3" mbrp downpipe, PROFAB EGR delete pipe,, manifolds,,and uppipes. ARP headstuds. Trans-go jr. Quad 2 for now. Edge Insight CTS.
EFI someday
cuse diesel is offline
post #8 of 13 (permalink) Old 02-23-2010, 07:59 AM
Durallymax's Avatar
I was gonna say it sounded like a subpar mechanic who didnt want to trace wires. We all hate doing it from time to time, but if youve had to replace that many sensors its time to look elseware.
Durallymax is offline
post #9 of 13 (permalink) Old 10-12-2011, 07:15 PM
Lincoln Diesel
Aaron@LDS's Avatar
I know you posted this a while ago...
I just upgraded to EFI Live. And I am still waiting for my tunes. But When I tried to start the truck after unhooking the Edge. It wouldnt start. Crankshaft position sensor. I think the edge blew it. Now it only runs with the Edge hooked up. U have any more info about this?
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #10 of 13 (permalink) Old 10-13-2011, 07:37 PM
prick62's Avatar
Mine would only run without the Edge. When the Edge was hooked up it did not run so we told the shop to throw the F'N thing away and it has ran ever since!
prick62 is offline
