1300 rpm sound - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 30 (permalink) Old 04-25-2010, 11:37 AM Thread Starter
Storm59's Avatar
I replaced my Idler pulleys as well as the tensioner. Thinking this was my problem with the noise, but the noise remains. Always consistent 1300 rpm only at about 20 - 40 mph. It is quite annoying. I have not experienced any performance issues nor any failures. To really enhance the noise driving in an alley or alongside a hiway barrier really make it audible.
06 LBZ Silverado LT - Allison
Bullydog GT Tuner
K&N Intake
16" RaceOne Mags & Bridgestone Revo II
LED Dash Mod
Projector HID Lights High And Low with 4 light Mod
Rigid Dually LED Fog & Driving Lights
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
post #12 of 30 (permalink) Old 04-25-2010, 11:54 AM
Hooligan's Avatar
I have that very same noise in my 06 LBZ
have been all over my truck trying to find
it... Glad i am not the only one. But it is
realy annoying
By the way great site I have been doing
a ton of reading, this is my first post.
Hooligan is offline
post #13 of 30 (permalink) Old 04-25-2010, 02:09 PM
K.Lems's Avatar
I believe I have this sound as well seems very noticable at shutdown of the truck. Similar switching noises at idle too. I have a 07 LBZ.
2007 GMC Sierra Classic - LBZ
4" mbrp turbo back exhaust
s&b cai
EGR Blocked and Fingersticked
http://www.getsomeperformance.comDon't you think its time you got some!
www.alligatorperformance.com
K.Lems is offline
post #14 of 30 (permalink) Old 04-25-2010, 11:38 PM
B Rack's Avatar
More to add. The sound I get at 1300 rpm is never heard when the engine is cold but (could be due to engine being louder trying to warm up) once it gets warm and I baby it for the mpg it is brutal. I can hear it best when shifting 1-2 and 2-3 being gentle. It's definatly a muffled quick rattle. I have vibration in the cab ( may not be related) and can hear a similar sound while in park at idle or in drive but seems to away when I let of the break to go. Still have no clue where tho. I tried having the wife rev to 1300 in park. No luck with that.
I'm desperate for a fix on this one guys. Losing sleep. Could this be a TQ issue?
Bracken from Spudville
04.5 LLY
EFI'D
6" stack
Sleeves
33in cooper stt's
- EGR Blocked - AFE Turbo MP - PCV Re-routed
Originally Posted by Diesel Dan View Post
Get a speedometer with two marks: off, and Haulin' ass
B Rack is offline
post #15 of 30 (permalink) Old 04-26-2010, 01:34 PM Thread Starter
Storm59's Avatar
I dont experiance any vibration...ever. But yes it is only present after the engine is warm. I tried it with the belt off and it is still present. Same paramters, 1300 rpm ... 20 - 40 mph. I don't get the sound at idle though nor at shutdown.
Bullydog GT Tuner
K&N Intake
LED Dash Mod
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
post #16 of 30 (permalink) Old 05-05-2010, 07:01 PM
FmFuller's Avatar
i have noise that sounds like someone stretched the mouth of a ballon and letting air out slowly
FmFuller is offline
post #17 of 30 (permalink) Old 06-29-2010, 02:53 PM
por2gzo's Avatar
Send a message via Yahoo to por2gzo
I have this same sound ... WHAT IS IT !
2006 LBZ CC/SB SLT GMC in Blue Graphite Metallic
8" FabTech lift | Amp Research Power Steps
18x10" Raceline Renegade 8 Wheels
35x12.50R18 Nitto Trail Grapplers
Super Chip Flashpaq Programmer
S&B Cold Air Intake Kit
4" turbo back Strait Pipe with 6inch tip (Home Fabbed)
Fox Shox All the Way around
Firestone Airbags in the rear
30" Bulldog Bone Edition LED Light Bar
AND ALOT OF GOODIES IN THE INTERIOR !
por2gzo is offline
post #18 of 30 (permalink) Old 06-29-2010, 06:14 PM
Administrator
jc1843's Avatar
Check the boot at the lower left side of the inner-cooler and might as well check all others. They get loose and let boost excape. Also check for wear hole in the boost tube at the PS hose-- the hose may contact the boost tube and wear hole.
Also-- at the top of the forum-- click on user and fill out your information in the signature-- No one knows what you drive-- but YOU! It helps when you ask a question.
jc1843 is offline
post #19 of 30 (permalink) Old 07-03-2010, 09:29 PM Thread Starter
Storm59's Avatar
I tried the usercp options and have the signature filled out and the box checked, but it wont show up.
any ideas
Bullydog GT Tuner
K&N Intake
LED Dash Mod
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
post #20 of 30 (permalink) Old 07-03-2010, 09:32 PM Thread Starter
Storm59's Avatar
any ideas
well look at that now it works
Bullydog GT Tuner
K&N Intake
LED Dash Mod
4 inch Exhaust
Coming Soon:
4 inch lift
Bullydog Pyrometer
Storm59 is offline
