rear pinion seal? - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 10-11-2010, 09:17 AM Thread Starter
rear pinion seal?
well, i went to Denver and picked up a set of these tires/wheels
and when i got home i noticed fluid on the pumpkin... looks like rear pinion seal, anyone know how much for dealer to replace... i could probably do it myself, but don't have much time or patience
i did find the seal for $31 at O'Rielly's... not sure that it is the right one though
Rattlin & Gobblin
2006 Chevy 4x4, CCSB, LLY, 225s on forged alum 19.5 Ricksons, MIA muffler
Husker Diesel | 402-502-6961
Kst8er is offline
post #2 of 21 (permalink) Old 10-11-2010, 09:54 AM
tonymontana13's Avatar
All u do is take the driveline off than take the 12 point nut off the pinion than u will prolly need a mallet and hit off that balancer thing than take the seal off and put the new one on and that u have to torque it exactly how it is now because than. It will mess with the backlash I believe I'm sure smeone will correct me but if u don't tighten it enough it will be toouching the ring gear to much but if u tighten it to much it won't be toucking it enouch so I guess its ur call maybe be better to have someone do it but I bet it would only take an hour maybe an hour and a half
Gabe 23
03 lb7 crew cab short box
10 inch cognito lift,37 1350 20 ss m16, 20x12 956s, 4.56 gears
Pioneer door speakers and tweeters 7inch double din dvd 2 10' cvr zx750.1 amp
4 inch straight pipe turbo back with 6 inch tip
intake horn mod, afe stage 2 intake
Efi live dsp5-duramax tuner
PPE Stage 5 By Diesel DayDreamshttp://www.performancetruckproducts.com
tonymontana13 is offline
post #3 of 21 (permalink) Old 10-11-2010, 09:57 AM
Mine is leaking too
2003 GMC 2500 Big dipper trans, dual cp3, s366, EFIlive, trac bars, steering braces, lockers
1998 Dodge 2500 24v cummins BHAF 4" exhaust 6" stacks edge juice with attitude 6" procomp lift
1995 Doge 2500 12v Pump work hood stack
justinwilliamskx is offline
post #4 of 21 (permalink) Old 10-11-2010, 10:02 AM
ramonday's Avatar
It'll run you between $250 and $300 if you can get them to use your parts. A lot of dealers are snotty and want that part markup. Regardless, you can bet on about 2.5hrs or so of labor. And TM13 is right about the tolerances. I'm not sure, but you may have to replace the crush sleeve. But you definitely need to get the preload correct or you'll burn the bearings up. I personally don't like working on rear ends.
2004.5 GMC Sierra SLT EC 2500HD 4x4 LLY w/LBZ MP, PCV reroute, EGR blocked, 4" exhaust, PacBrake TR sleeves, DSP5 & EFI-Live w/Idaho Rob tunes
ramonday is offline
post #5 of 21 (permalink) Old 10-11-2010, 10:24 AM
Vrabel's Avatar
Okay, listen up. Here's a safe way to do it. First mark postion of drive shaft mounting to yoke. Second, remove shaft. Third, take a sharp pointed punch and hammer and put a mark on pinion nut and end of shaft inline with each other. Fourth, remove nut "Important" count the amount of turns you make because that is your bearing pre-load. Fifth, Replace seal and clean yoke. Make sure you dont have a worn ridge where seal rides. Sixth, Put a light coat of rtv on inside spline and a light coat of grease where seal rides. Seventh, Replace yoke and replace nut turning the "EXACT" amount of turns to remove. Align marks being very careful you dont go past. Refill and replace shaft.
R.I.P.
2001 Chevy CC/SB 4WD EFI Live DSP 5, LBZ Short Block, Cut LB7 Pistons,keyed crank and cam, balanced,LBZ Intake Runners with RDL Shorty Y-Bridge, EPR Twins, Big Dipper 40% overs, MBRP Cool Duals, LBZ CP3, ADII, BD Manifold, C2 Gauges, H2 Wheels, Cognito Sleeves and Braces, Hids-Hi-Low-Fogs.
Sheet Metal Workers Local #22
If it's not made in America, YOU paid too much!
Creatures of The Night Performance and ProFab Performance
Vrabel is offline
post #6 of 21 (permalink) Old 10-11-2010, 10:30 AM
Administrator
jc1843's Avatar
Vribal has good advise-- Be aware-- to tight or to loose will damage the rear axle gears.
jc1843 is online now
post #7 of 21 (permalink) Old 10-11-2010, 10:47 AM
Vrabel's Avatar
also too tight changes your pre-load on pinion bearing. going past then back to mark wont work. damage is done by squeezing crush collar too far.
R.I.P.
Vrabel is offline
post #8 of 21 (permalink) Old 10-11-2010, 08:24 PM
rascal810's Avatar
Originally Posted by tonymontana13 View Post
all u do is take the driveline off than take the 12 point nut off the pinion than u will prolly need a mallet and hit off that balancer thing than take the seal off and put the new one on and that u have to torque it exactly how it is now because than. It will mess with the backlash i believe i'm sure smeone will correct me but if u don't tighten it enough it will be toouching the ring gear to much but if u tighten it to much it won't be toucking it enouch so i guess its ur call maybe be better to have someone do it but i bet it would only take an hour maybe an hour and a half
do not hit a balancer with a hammer!!!!!!!!!!!!!!!!!!!!
2015 GMC 3500HD CCLB DRW
2008 LMM EFI Live by Nick, Transgo jr., Diamond Eye Quiet Exhaust with Quiet Tone Front Pipe, Big Blue Converter, Blocked EGR, Fass 150 lift, ITBC bypass, Heated Windshield Fluid CCLB Dually LTZ, Sulastics, Bilstein rear shocks, Sold
162,000 miles
2004 LLY RCLB 4x4 80,000 miles bone stock oil every 3k SOLD
2011 Chevy RCLB 4x4 LML 3500HD SOLD
2013 GMC CCSB 4x4 LML 3500HD
http://www.duramaxforum.com/forum/new-here-please-read/
rascal810 is offline
post #9 of 21 (permalink) Old 10-12-2010, 02:46 PM Thread Starter
well, i found this
anyone know the correct part number?
Rattlin & Gobblin
Kst8er is offline
post #10 of 21 (permalink) Old 10-14-2010, 04:35 PM Thread Starter
bump...
no one knows the right part number?
Rattlin & Gobblin
Kst8er is offline
