15 amp fuse in a 10 amp slot - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 10-28-2010, 09:47 PM Thread Starter
If I put a fifteen amp fuse in a 10 amp slot what will happen? My cab clearance lights fuse blew and it was a 10 amp fuse. I didn't have any so I put a 15 amp fuse in. I'm not an electrical master but what's the worst that could happen?
deeahgee
06 crew cab dually Budnik 19.5's with Hercs, Fox and icon Shocks, DMAX ecm, built tranny by Mike at Inglewood, AD165, 4" MBRP turbo downpipe 2 a 5" straight pipe , RAM AIR 2 a AFE stage 2 intake, AFE intercooler pipe, FS 2000 trany and engine filters, Mag-hytec tranny and diff, front and rear bumpers w/spray on liner, Recon cab lights, recon marker lights, HID's hi and low,4 kids, 3 tvs, 2 amps and a 6" exhaust pipe(ID).
deeahgee is offline
post #2 of 6 (permalink) Old 10-28-2010, 10:00 PM
JoshG's Avatar
the worst... melt down the wires.... BUT im goignto say your pretty safe wit hit. It isn't that big of a difference in the two.
03 LB7 CC/SB 185k 6in fab tech 35.12.5 17 stts
5in custom build exhaust into 6in stack axle dump. Built front bumper with 2 light bars. Hids, ppe hot level 3, fass, biv, intake, 2-8" sub, infinitys, alpine deck, PAC exhaust break, air horns, brand new front end, leds in everything,
Sheet Metal workers local #55
90 xj on 40s and tons 4 linked with coilovers and half backed.
JoshG is offline
post #3 of 6 (permalink) Old 10-28-2010, 10:43 PM
DuramaxForum Guru
dukcaln's Avatar
been there done that.....no issues
04.5 LLY ECSB 4WD On 22's, Ram Air Hood & Tonneau, 3" Drop w/Fox 2.0, Kryptonite Tie Rods, Kryptonite SS Center Link, Kryptonite Death Grip & Xtreme Idler Support, Kryptonite T-Case Brace, HSP Intake, HSP Turbo Inlet, HSP Hot-Cold Pipes, FASS 150-FASS Bowl Delete w/Beans Sump, PPE Fuel Mods, Built Trans w/Precision ML TQ - Idaho Robs EFI Live - 1/4 @ 13.01 - 103.8mph
dukcaln is offline
post #4 of 6 (permalink) Old 10-29-2010, 12:40 AM
ummm fire.... thats what the fuses are for. if you have current overflow there is no built in protection. remove it ASAP.
2008 Chevy 2500LT CC stock for now
2004 Malibu Wakesetter VLX Loaded with wetsounds
cmoroy is offline
post #5 of 6 (permalink) Old 10-29-2010, 12:55 AM
twinturbo3150's Avatar
I wouldn't do it! I have done it in emergencies but replaced it with the right amp when I got home.
twinturbo3150 is offline
post #6 of 6 (permalink) Old 10-29-2010, 01:13 AM
SteepyBS's Avatar
i did it for my dash lights just to make it home one time, but put the correct fuse in the next morning
btw andy, i think this is the first post ive ever seen you have that was not sarcastic or funny at all....you really are gettin to be an old man with a truck!
03 Chev CCLB
500HP on STOCK trans/fuel/turbo
built trans and lift pump coming soon!
special thanks to
ADP, ATP, HDP, UDP, BDDP, MJS
SteepyBS is offline
