Block Heater ? - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 01-26-2011, 04:28 PM Thread Starter
DMAX LML
JJ Dmax's Avatar
Send a message via AIM to JJ Dmax
Block Heater ?
Is it ok to plug in the block heater wile the engine is still hot? i really dont see how it could be an issue but seeing as how this is my first diesel and my first time plugging it in i wanted to ask to make sure. its not suposed to get REAL cold here tonight but i wanted to see how much of a difference it makes in warm up time in the morning. Thanks in advance for any advice!
Jonathan
2014 2500HD LTZ Z71 4X4, EDGE Insight, B&W Turnover Ball w/Companion. Bone Stock (for now)
2006 2500HD LBZ 4X4 6 speed Allison "LT3", Airaid Cold Air Intake, EFI Live DSP5 Tuned by Rob, PCV Reroute, Transgo Jr, EGR Blocker, HID Low/High/fog 8000K, Headligh All On Mod, Recon LED Smoke Cab Lights, Magnaflow 5" DP Back Exhaust, Autometer Boost/EGT Gauges, Edge Insight CTS w/Backup Camera, Holley 150gpm Lift Pump, Firestone Ride Right Air Bags, B&W Turnover Ball w/Companion - TRADED 1/13/14
www.atptrucks.com
JJ Dmax is offline
post #2 of 7 (permalink) Old 01-26-2011, 05:50 PM
Porno Joe's Avatar
yes you can plug it in. I know a bunch of guys that do.
honestly in florida i dont know why you would ever need to plug it in.
2007 GMC 3500 LBZ- built trans, TCT 466, dual pumps, studded one at a time, running a Fluidamper
Porno Joe is offline
post #3 of 7 (permalink) Old 01-26-2011, 05:53 PM
(JESUS)
MUDYZER's Avatar
hello;
i would not worry about plugging in your d-max unless it stays very cold for several days.
i see you live in FL. i don`t think you got much to worry about..LOL scott
2006 ECSB 2500HD 4x4 LBZ 285-75-16 nittos..
Pro-Flo 4" strait piped to 5" tip.
S&B cold air intake...
ALLIGATOR Diesel Tranny Lines....
Cognito pitman/idler arm support kit...
PPE tie rod sleeves....
EFI LIVE....DSP5....Trans Go Jr....thanks Jason
((((( JESUS )))))
MUDYZER is offline
post #4 of 7 (permalink) Old 01-26-2011, 05:57 PM Thread Starter
DMAX LML
JJ Dmax's Avatar
yeah i know its not needed here i just wanted to see if it made any difference on warm up in the morning. i know im not dealing with NEAR the cold you guys up north are dealing with. its more me being like a kid in a toy store wanting to play with all the new toys and see what they do LOL
Jonathan
www.atptrucks.com
JJ Dmax is offline
post #5 of 7 (permalink) Old 01-26-2011, 06:00 PM
i plug mine in as soon as i get home from work havent had any problems... all it does is heat the coolant in the engine making it easyier to start. also gives ya heat in the cab faster since the coolant is already somewhat warm
2004 Chevrolet 2500HD regular cab long bed LB7 Duramax
EFI Live Tuned By Day's Diesel
Glowshift Pyro & Boost Gauges
MBRP 4" Exhaust
Rhino Line bedliner
B&W Goose Neck Hitch
Windows Tinted 15%
Recon Tailgate Light Bar
Powdercoated Stock Rims
Goodyear Silent Armors 285/75R16
Next: Fass fuel system, Stage 4 trans kit,
epro is offline
post #6 of 7 (permalink) Old 01-27-2011, 09:53 AM
saw what you did there
theunderlord's Avatar
http://www.duramaxforum.com/forum/ho...eater-faq.html
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #7 of 7 (permalink) Old 01-27-2011, 10:03 AM
mwar410's Avatar
I never knew I had one until last year when my glow plug circuit went down. I don't normally plug it in unless it's less than 10 f. And then I run it while the truck is still warming up, never had any problems yet.
GMC 4.5 lly ext cab SLT
EFI live ATP,
4" magnaflow catback, magnaflow down pipe, pcv reroute,nicktane filter adapter, Fuel race valve,duramax tuner LBZ induction kit, BD High flow manifold,SDP full EGR delete w/ LB7 up pipe
Rareparts G2 tierods, rare parts pitman, ultimate idler arm, supersteer idler pivot, cognito UCAs leveled with 315/70/17's, Monomax shocks, energy suspension; body mounts, tranny mount and control arm bushings, and yes it rides like a brick
Cen Pe Co diesel max fuel additive,Cen Pe Co Para/syn oil
mwar410 is offline
