Improve Fuel Mileage... - Chevy and GMC Duramax Diesel Forum
post #1 of 20 (permalink) Old 03-02-2011, 01:34 PM Thread Starter
duramax07tmd's Avatar
Arrow Improve Fuel Mileage...
Just like everyone else, I am trying to get better fuel economy. I understand that the winter fuel does have an impact but I want to go over what I have done to try and improve overall fuel mileage. Lately I have been doing a lot of in town city driving and I know that does not help. Most of the year I get about 16-18 around town and 20-22 on the road and That is pretty good and I am happy with that. But right now, I am getting anywhere between 11-13 in town driving. I am in the middle of doing a fuel analysis with Stanadyne and it seems to have helped so far. I will post a write up once I have completed my little test or whatever you want to call it. Keep in mind, all of the MPG that I have posted above have been hand calculated, im not paying attention to the DIC. I am not towing anything at the moment.
Note: All of this driving has been done on my fuel economy tune, under what I consider "normal conservative driving" light on the skinny pedal and no hard take offs. (grandpa driving)
What I have done so far:
-New trans fluid and spin on filter.
-New oil and filter
-New fuel filter
-Cleaned air filter
-Cleaned MAF
-Bumped up air pressure in tires to around 80 PSI (running 285/75/16 Michelins)
You can see what has been done to my truck in my sig.
I have noticed a slight decrease in MPG as soon as I installed the blocker plate, but that was right around the time winter fuel started last year so idk if its just in my head.youcrazyy
Will have to say that diesel is not the highest or the lowest around here so I do consider myself lucky. Its around $3.78 here now. 2 weeks ago it was $3.50
Just wanted to see if I have missed anything here and I am open to all suggestions to help out the mileage since diesel is going up.
Thank you :rockin
07 Chevrolet LBZ
White CCSB 4x4
06 TrailBlazer SS
EFI Live DSP5|AirDog II 165| Flex-A-Lite Electric Fans| 2" Drop Shackles| 5" MBRP Exhaust| Down Pipe| S&B Intake| PPE & Aeroforce Gauges| 20x9 XD Hoss 795| 305/55/20 Falken Wild Peak A/T| PPE Fittings| PCV Reroute| EGR Blocked| HD Tie Rod Sleeves| B&W Hitch| 10" Kicker Comp VR
duramax07tmd is offline
post #2 of 20 (permalink) Old 03-02-2011, 02:12 PM
2500HD Club Member
maineloggerlbz's Avatar
How long do you let your truck idle in the morning?
2011 LML ccsb slt- H&S Xrt Pro- 5" flo pro straight pipe- S&B intake
Thanks to alligator performance
maineloggerlbz is offline
post #3 of 20 (permalink) Old 03-02-2011, 02:14 PM
CAGLE DURAMAX's Avatar
blocker plate will decrease your mileage you need to go ahead and spend the $$$ on an EGR delete kit that reroutes everything. blocked mine once and mpg when to shit so now im gonna go with an allseason egr delete kit
Forrest
2007 LBZ CC/SB SLT 4x4, 5" Magnaflow SS, S&B CIA, Firestone Airbags, Dominator III steps, De-Badged, 5% on windows with 40% on windshield, 5K HID's w/ All-On-Mod, Edge CTS Insight, SDP EGR delete w/ boost probe, Batmowheel, ATP tunes, PCV reroute w/ plug, Kryptonite Tierods & Centerlink, Cognito UCA's, Bilstien 5100's, Airdog II 165, ATP Intercooler pipe, Pump rub upgrade and Transfer case brace, Trans repair lines, LML manifold, SS brake lines, Sulastic springs, ATS pans, ATI dampner, drilled and slotted rotors with ceramic pads, 295/70-17 Trail Grapplers on H2's
Thanks Dustin and Rob at ATP and Steve and Zack at Glissions Diesel Performance
CAGLE DURAMAX is offline
post #4 of 20 (permalink) Old 03-02-2011, 02:15 PM Thread Starter
When its cold here (below freezing) ill let it warm up for about 10 min. Lately it has been anywhere between 40-50 in the morning and Ill let it warm up for a few minutes enough to get everything flowing.
07 Chevrolet LBZ
White CCSB 4x4
06 TrailBlazer SS
post #5 of 20 (permalink) Old 03-02-2011, 02:22 PM
I'm That Guy...
TDFDiesel's Avatar
I have seen that driving it like a "grandpa" is not necessarily the best way to improve fuel mileage on your truck. Obviously taking off fuel throttle won't be good either, I find I get the best fuel mileage driving "normal".
I suggest you try a different fuel station miles away. I can see a 2+ mpg difference from one station to another.
You can actually get samples of your fuel and send them off for analysis.
I would clean your MAF again now that you've recently cleaned your air filter as well.
Tony
Old Trucks: 3 - LLY, 1 - LMM
TDFDiesel is offline
post #6 of 20 (permalink) Old 03-02-2011, 02:24 PM Thread Starter
Ok, I will look into a different station. MAF sensor was cleaned today:rockin
07 Chevrolet LBZ
White CCSB 4x4
06 TrailBlazer SS
post #7 of 20 (permalink) Old 03-02-2011, 02:34 PM
Administrator
jc1843's Avatar
If you have not re-calibrated the speedo-- you are traveling farther than you are recording on the odometer. Many tuners have a tire size option--The dealer will not do it and they will say they cannot.
Be sure to use manual computing, as most DIC reading are not correct.
jc1843 is offline
post #8 of 20 (permalink) Old 03-02-2011, 02:42 PM
jscho338's Avatar
Draft other vehicles AS MUCH AS YOU CAN! This is a huge MPG increase technique thats free and works...
2005 Chevrolet 2500 LT Deluxe - 4" MBRP cat-back - aFe MP - EGR blockoff - EFI Live DSP5 by Rick at Extreme Engine Development - 15% over injectors - Built motor by Curtis Halverson at Extreme Engine Development - Amsoil Dual Bypass Filter setup - 8" Fabtech Lift - NADP Heavy Hauler Race Trans & TCase - Rare Parts HD Tie Rods - MOOG Idler/Pitman Arms w/ Cognito Braces - AMP Research Power Steps - 20" RBP 94R's (-25 offset) w/ 355/60R20 Kumho Venture A/T's - 4.56 gears - Debadged - Bushwacker Flares - Smoked Tails - All on mod - LED interior light conversion - Autometer Sport Comp II Pyro/Boost/Fuel Press. - 20% tint all around
WISH LIST: Twins, Dual CP3's, Turbo-back exhaust, Tow Mirrors, ...the list continues to grow!
jscho338 is offline
post #9 of 20 (permalink) Old 03-02-2011, 03:32 PM
I'm That Guy...
TDFDiesel's Avatar
When did you clean the air filter?
Hopefully the fuel station will help you out.
Tony
post #10 of 20 (permalink) Old 03-02-2011, 06:42 PM Thread Starter
The air filter was just cleaned, speedo is calibrated, and I will try and draft more lol.
07 Chevrolet LBZ
White CCSB 4x4
06 TrailBlazer SS
