Need a little help - Chevy and GMC Duramax Diesel Forum
post #1 of 7 (permalink) Old 03-20-2017, 02:14 PM Thread Starter
Need a little help
Just got done doing headgasket and now have an issue with smoke out of the exhaust. The smoke gradually gets worse the longer the truck idles. Once ya go and get going smoke clears up and is almost non existant. Any ideas of where to start looking? Thanks in advance
Llyjunkie05 is offline
post #2 of 7 (permalink) Old 03-20-2017, 02:24 PM
Administrator
jc1843's Avatar
Do you have any codes/check engine light-??
What color smoke--??
Assume this is a LBZ engine-??
jc1843 is online now
post #3 of 7 (permalink) Old 03-20-2017, 04:01 PM Thread Starter
Yes an lbz truck. 2007 cclb 105k miles. No codes, truck runs flawless, no loss of power, no rough idle. Smoke is a whitish gray. But can definitely burning smell of oil in the exhaust.
post #4 of 7 (permalink) Old 03-20-2017, 07:29 PM
Administrator
jc1843's Avatar
Possible that you have a damaged piston/rings-- remove the oil fill cap, run the engine, and see it it shows signs of excessive crankcase pressure.
post #5 of 7 (permalink) Old 03-21-2017, 01:48 AM Thread Starter
Have checked the oil fill cap. Nothing excessive. It doesn't blow the cap off when I flip it upside down. Only thing that was done that I think could be causing it would be valve guide seals, I had the machine shop do them. Open to ideas as I am stumped.
post #6 of 7 (permalink) Old 03-21-2017, 08:59 AM
where are you located?
is it cold out? just wondering? it cold be you still have a small leak and as the motor heats up it seals the leak.
kobrak is offline
post #7 of 7 (permalink) Old 03-22-2017, 10:03 PM
Tonkatoy77's Avatar
You had a shop do valve guide seals at 105k? Were they leaking when you took the heads off? Did you do anything with the turbo when you had it apart?
07' Chevy Silverado LT3 ccsb LBZ. 8" Bulletproof lift kit(junk), Fox shocks, EFI Live by Kory, Edge CTS Insight, 4" Silverline downpipe back exhaust, PPE FPR shims, PPE fuel rail fitting, pcv reroute, resonator plug, Transgo jr, S&B Intake, Amp steps, 20" XD Racing wheels, 36" Goodyear Duratrac tires, Air Lift rear air bags with wireless compressor, billet grill, debadged, Caddy gauges.
77' Ford F-250 factory highboy. 460, hooker headers, 3" flowmaster exhaust, MSD ignition, Comp Cam, Edelbrock high rise intake, Holley 750 cfm double pumper carb, Holley fuel lift pump, Autometer gauges, 3" lift kit, 38" Toyo tires, 18" Weld wheels.
Tonkatoy77 is offline
