black smoke - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 06-05-2011, 09:46 PM Thread Starter
racegunnr's Avatar
black smoke
my 07 classic has started to spew out some black smoke out of the tailpipes since the weather has started to warm up. i am running the edge cts on level 3. no towing. she smokes pretty good when lugging up hills and from a stop with medium acceleration. kinda worries me. thanks.
07 classic, stock susp. silverline turbo back dual exhaust, edge evolution cts programmer w\egt,Titan aftermarket 46 gal. fuel tank and a loose nut behind steering wheel.
racegunnr is offline
post #2 of 5 (permalink) Old 06-05-2011, 10:22 PM
Oldvintageiron's Avatar
thats normal, Hot air is bad air. Mine does the same thing
2004.5 lly GMC CCSB 2500
Stock LBZ intake, AFE MP, Afe IC Tubes both sides, MBRP DP w/ heat wrap
BD manifold, EGR block plate, Banks turbo back(no cat) ,coolant bypass filter
EFI Live by IDAHOROB w/DSP5http://www.atptrucks.com
Aeroforce Interceptor gauges, ARP studs,
19.5 Rickson wheels W/ 225/70/19.5 drive/ steer
BD Flowmax Lift pump, auxiliary fuel filter PPE fprv shim
Bullydog shift enhancer/ Amsoil Race Trans Fluid, MA pump rub fix.
Amsoil Bypass Filtration, Amsoil 3000 5w30 oil
Cognito Motorsports Pitman/ Idler support kit,Secondary Radiator system built by me
Oldvintageiron is offline
post #3 of 5 (permalink) Old 06-05-2011, 11:15 PM
taylorbok's Avatar
egr delete will clean it up a bit
2007.5 lmm CCSB black, bullet proof bumpers.
efi live (motor ops), cts insight, 5" straight pipe, 7" bds lift, 37" toyos on fuel maverick, egr blocker,
taylorbok is offline
post #4 of 5 (permalink) Old 06-05-2011, 11:32 PM
Duramax-LML's Avatar
I wouldnt be worried, whenever its warmer out with humid air you will see more smoke then ever
Name: Jake Age:26 INSTAGRAM: @jakethomaspnw
2013 Duramax LML CCSB LTZ My Build Thread
SPORTSMAN CP3/ S369SXE/ 30% OVER EXXERGY INJECTORS, FASS 150, diamond eye 5" TB,6" Fabtech Lift no bolts, 35inch Toyo M/T, 20x12 Fuel Octanes,ISSPRO EV2 GM MATCH, BOSS grill,Fusion front and Iron Cross rear, Pioneer In dash, subs, ARB twin air compressor, Cognito UCAs
Duramax-LML is offline
post #5 of 5 (permalink) Old 06-06-2011, 09:09 PM Thread Starter
racegunnr's Avatar
Thanks gentlemen!!!
