afe intercooler tube for lbz - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 02-07-2013, 05:44 AM Thread Starter
LBZ-DuraMax06's Avatar
i wanna order the afe intercooler tube but just wanted too see if anybody has it on there lbz? Is there any difference in power wise and cooler egts? It is says 67% more flow over stock. And wondering if it makes the turbo any louder? Thanks for the help!
2006 GMC CCSB LBZ, Debadged,5 inch mbrp with 4inch downpipe 6inch tip,AFE stage 2intake, EFI Live DSP5 tuned by duramaxtuner, Cts insight.EGR blocker plate.Cognito UCA, Bilstiens, MA sleeves.
LBZ-DuraMax06 is offline
post #2 of 4 (permalink) Old 02-07-2013, 06:36 AM
it dropped egts around 150 degrees. cools down quicker. better fitment. won't make turbo louder that depends on your intake.
2006 SILVERADO 2500HD 4WD CREW CAB W/T LBZ 285/75/16 AT2's, Kryptonite centerlink and tierods, Cognito braces, 3" shackles, AFE full metal intake, SDP egr delete pipe, 3" intercooler pipe, LML exhaust manifold, PCV reroute, Batmowheel, CTS gauges, MA pump rub fix, Transgo Jr kit, MBRP 4" straight pipe dumped, MBRP downpipe, EFI live dsp 5 Idaho Rob tunes, AD2 165, Debadged, Gooseneck hitch
1993 DODGE CUMMINS W350 4WD CC DRW
streetbrand1 is offline
post #3 of 4 (permalink) Old 02-07-2013, 07:08 AM
rugbyman87's Avatar
hmmmmm
Dominic:2006 GMC 2500HD CCSB LBZ 305/55/20 Terra graps with chrome makos, 4" magnaflow SP, R1 concepts dimpled and slotted rotors, Tie rod sleeves, Leveled, Recon NBS cab lights, ebay clear headlights, blacked tails, Totron LEDS in bumper, EGR block, CTS w/probe, Kory DSP5, transgo jr.
1984 Silverado 6" Total lift 35" all terrains,3 yr resto,SBC 350- 428hp-378ft/lbs,built 700r4 in it with a built 2400 stall converter,Chevy 10bolt and 12 bolt, 4.56 gears, eaton limited slip,14.62 @ 90.16 mph...
http://www.syntheticmotorsports.org/content.php
My Boat build thread-http://www.duramaxforum.com/forum/gas-burners/299946-my-boat-build-thread-dock-tease.html
rugbyman87 is offline
post #4 of 4 (permalink) Old 02-07-2013, 07:13 AM
Porno Joe's Avatar
is the AFE a straight shot in the intercooler? or does it have the bend jsut like the factory?
I have the banks, seemed like a good upgrade to me.
2007 GMC 3500 LBZ- built trans, TCT 466, dual pumps, studded one at a time, running a Fluidamper
Porno Joe is offline
