Lift Pump - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 07-01-2013, 06:07 PM Thread Starter
husker_fan's Avatar
Lift Pump
Just curious, do most people put a lift pump on right away, or go with a cat filter adapter? I was told hardly anyone wastes the money on the cat, and most just put the pump with filters on instead. Quite a price diff, and I was under the assumption a lift pump wasn't necessitated until higher HP levels than my stock ally would take.
2006 LBZ CCLB
3" Downpipe
5" Magnaflow straight pipe
Predator tuner
husker_fan is offline
post #2 of 8 (permalink) Old 07-01-2013, 06:10 PM
Goose2448's Avatar
I'm running a Adaptor with no lift pump. I am going to get one, just not in the budget yet. It cheaper to run cat or Donaldson filters than the stocker. When I do get a LP I'm keeping the Donaldson.
2008 GMC 3500HD CC LB DRW 4x4~Westin Step Bars, WeatherTech Floor Liners, Antenna "Delete", Plasti Dipped Grill and Emblems and Rims, Leveled, Funky Gear Rims, Nictane Adapter with Donaldson and Clear Bowl, 3" Magna Flow Down Pipe, 5" Diamond Eye Exhaust Dumped, EFI By Kory, Crobra 29LTD WX/BT/NW CB, Dual 4' Firesticks, Recon Roof Lights, Reese Pro Series 15K 5th Wheel Hitch
1985 Chevy C20 RCLB 350 4 Bolt, 4 Barrel Carb, 4.10 Gears, 8600 GVW, Glass Packs Dumped, Pig Skin Leather, Bed Mounted 5th Wheel, Dual 20 gal Tanks, 62,146 Miles, Indian Bronze and Cream~Rolled
DF DRW Club Member 129
Goose2448 is offline
post #3 of 8 (permalink) Old 07-01-2013, 06:16 PM
BambiAssassin's Avatar
A lift pump definantly supplys better filtration (assuming you go with an Airdog or fass) than the cat. But like you said, with a stock trans you most likely won't be losing rail psi. The way I see it, a lift pump is definantly not money wasted, but it's not absolutely nesecary under stock applicantions. (Excluding LB7's).
Make sense?
Corey
03 RaceCab in the works.
BambiAssassin is offline
post #4 of 8 (permalink) Old 07-01-2013, 06:16 PM
sickgmc's Avatar
I put a airdog on my truck the other day and took the stock filter off. truck runs great and I have stock trans tuning from atp and the lift pump made night an day on full throttle runs.
06 silverado lbz
05 sierra (show truck)
sickgmc is offline
post #5 of 8 (permalink) Old 07-01-2013, 06:18 PM
Cknight199's Avatar
Originally Posted by BambiAssassin View Post
A lift pump definantly supplys better filtration (assuming you go with an Airdog or fass) than the cat. But like you said, with a stock trans you most likely won't be losing rail psi with a stock trans. The way I see it, a lift pump is definantly not money wasted, but it's not absolutely nesecary under stock applicant. (Excluding LB7's).
Make sense?
Exactly. I have ran a fass 150 titanium with the two filters it came with as well as he stock filter with no problems.
Sent from AutoGuide.com App
LBZ, Built Motor. S483, Plenty of fuel.
Cknight199 is offline
post #6 of 8 (permalink) Old 07-01-2013, 09:45 PM
Dmaxjunky's Avatar
Im running just the cat filter. But when I have an extra 500 bucks im gonna get one just to check it off the list.
2006 lbz ccsb
Edge Evo - Nicktane adapter, 5" Magnaflow strait piped , 3" Crown drop shackles , 20x9,0-Offset,AE wheels. 33" Couriga M/T, DDM tuning 35w- 5000k h.i.d. (Lows and Fogs).Aftermarket mesh grille. 20%tint all around 5% viser.
Dmaxjunky is offline
post #7 of 8 (permalink) Old 07-03-2013, 04:36 PM
Go Green!
Blackcloud556's Avatar
id say if you have the money go with the lift pump.
If you are scrimpin, get the cat adapter
Blackcloud556 is offline
post #8 of 8 (permalink) Old 07-03-2013, 04:52 PM Thread Starter
husker_fan's Avatar
Its a catch22. I have the money, but I have a wife. I have to figure the price X 2 for everything, because that's what it'll end up costing me in the end.
2006 LBZ CCLB
3" Downpipe
Predator tuner
