Check your Radiator cap. Its not returning coolant from the catch tank. (like a check valve). Coolant gets hot and expands, flows into tank .Coolant in radiator cools down and can't suck back. hoses collapse.
However, I see it all the time.....look over at the coolant level in the surge tank, and it's low. Top it off to full, upper hose keeps it shape. :thumb
For the Dexcool used in the system to perform correctly as an inhibitor between dissimilar metals, it's important to keep that tank topped off, lest air accumulates in the system, which can cause deterioration/rust/coolant sludge.
I have no idea. Could the leaking pump cause vacumn or something to make my hose go flat? Coolant is leaking down bottom side of pump area on drivers side.
The coolant expands when warm and the reservoir cap lets air out.
When the coolant cold, the coolant contracts-- and the reservoir cap is suppose to let air back into the system-- but if the cap is sticky-- it may not let air in, so the system is under a "Vacuum" and the hose collapses.
As noted above, clean or replace the reservoir cap.
When the waterpump is bad, it usually leaks coolant out of a small vent hole [weep hole]. That weep hole is located above the lower radiator hose where it attaches to the waterpump.
Changed the air filter in my truck today and I haven't driven it for 4 days , popped hood and noticed my upper hose collapsed . Drove for a bit and pulled over and checked when engine was up to temp , the hose was back to normal. I'll check the cap later or tomorrow . Thanks for the suggestions guys . Oh and the level in the tank was normal and at the full line with the engine cold and sitting for 4 days .
207K members
