EGR- delete or block? - Chevy and GMC Duramax Diesel Forum
post #1 of 11 (permalink) Old 12-27-2010, 07:16 PM Thread Starter
Porno Joe's Avatar
on my 07 LBZ, which is my daily, should I simply block the EGR or buy a full egr delete kit?
2007 GMC 3500 LBZ- built trans, TCT 466, dual pumps, studded one at a time, running a Fluidamper
Porno Joe is offline
post #2 of 11 (permalink) Old 12-27-2010, 07:19 PM
GaBoy25's Avatar
Depends on the coin you want to spend. Plates can leak. Im gonna do the delete when I can figure out what else to drop 200 bucks on.
A part here or there
GaBoy25 is offline
post #3 of 11 (permalink) Old 12-27-2010, 09:58 PM
weldman's Avatar
whats the benifits for deleting the egr and who make the best one?
2006 gmc dmax.lbz cc.sb. 4 inch exhaust int 6 inch stacks, k&n intake. diablo sport predator EGR blocker plate with fingerstick,afe mouthpiece glowshift gauges pyro,boost,6000k low and fogs
weldman is offline
post #4 of 11 (permalink) Old 12-27-2010, 10:03 PM
saw what you did there
theunderlord's Avatar
No more egr, that's the benefit! Less soot in the manifold, sdptwins.com makes a nice kit!
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #5 of 11 (permalink) Old 12-28-2010, 09:26 PM
FlyinMonkey's Avatar
gasket up both sides if it leaks
2006 LBZ CC SLT with the Anti-Poon interior
4in MBRP Turbo back
3in DSL Down pipe
K&N Cold Air Kit
EGR Blocked
Turbo Plugged
Transgo Jr.
EFI
Helper Springs
285 toyo open country A/T's
FlyinMonkey is offline
post #6 of 11 (permalink) Old 01-03-2011, 07:00 PM
Why do you want to block or delete the EGR? I just put a quadzilla 2 on my truck 2007 LBZ and every 150 miles or so it kicks out the 0402 EGR code. Is that why you want to block yours? Dont you thing the tuner companys could program the stuff to do it? Mines drivin me crazy. Love the tuner but hate the friggin engine light.
mercstorm@aol.com is offline
post #7 of 11 (permalink) Old 01-03-2011, 07:04 PM
I STILL DGAF
Duraskank's Avatar
Fingerstick time?
GW: 2005 CHEVROLET LT CCSB LLY 4WD|SOLD|SkankLilly
2006 GMC SLT ECSB LBZ 4WD -SOLD skankmobile2dot0 Pics
2007 CHEVROLET LS CCSB LBZ 4WD|June ROTM 2011 - SOLD|Dmax Pics
07.5 CHEVROLET LT2 CCSB LMM 4WD|SOLD|LMM 'build' thread|LMM pics
2011 GMC RCLB LML 4WD @duraskank
Duraskank is offline
post #8 of 11 (permalink) Old 01-03-2011, 07:11 PM
Whats a finger stick? I suck at the new age of electronics & computers. Im old school.
post #9 of 11 (permalink) Old 01-03-2011, 07:16 PM
I STILL DGAF
Duraskank's Avatar
It's a circuit that modifies the maf signal and prevents the egr codes from being thrown.
How To: Fingerstick installation made easier
post #10 of 11 (permalink) Old 01-03-2011, 07:18 PM
BAD ASS LBZ that is
BALBZ's Avatar
well i would say delete it. I used SDP,s kit the only thing with deleting it is you will have a engine light due to deleting the intake air heater unless you are running EFI and you will crack your up pipe bellow unles you cut off the riser and weld it shut. Or you can make a simple (L) bracket like i did that bolts the riser to the moter (using a existing hole that bolted the EGR moter down)to eliminate the vibration. Mine was blocked for a year or so with no problems so i ges its all in how much effort and money you want to put into it. You will get better air flow by deleting it and will drop a fue LB,s by geting rid of the EGR moter.
Chad
White 2006 GMC Sierra 2500 CCSB LBZ 4wd
Built, 4" MBRP, RDL manifolds/uppipes, PPE stage 5, Dacco five disk TC, T-case pump upgrade, AFE boost tube, ADII 165
EFI by Rob, 2 turbos and 2 pumps, 45% sticks, 2" drop shackles, 60" Tbars, 285/50R20 Cooper Zeon LTZ's
20x10 Ion's, Billet centrlink, Cognito idler/pitman supports, SS sleves
Anzo taillights, Amsoil Front to Back
CUMMIN STROKE THIS DURAMAX SUCKER
BALBZ is offline
