EGR Delete and Mileage - Chevy and GMC Duramax Diesel Forum
post #1 of 18 (permalink) Old 02-02-2011, 05:00 PM Thread Starter
Duramax Dealer's Avatar
Has anyone gained mpg when doing the egr delete? Does the egr delete make your truck smoke more?
2006 Crew Cab Short Bed LLY
mods-4'' straight pipe with a 6'' tip, Autometer Boost and Pyro Gauges, AFE turbo inlet tubes, AFE Turbo Intercooler Tube, AFE Stage 2 Cold Air Intake with Pro Dry Filter, SXP 3'' turbo down pipe, EGR Blocked with finger stick, EFI Live SPADE DSP2 by Nick at Duramax Tuner and sold to me by Tyler at Meyer Performance
Duramax Dealer is offline
post #2 of 18 (permalink) Old 02-02-2011, 05:13 PM
apelineman's Avatar
didnt gain any mpgs. almolst no smoke on my 525 tune and it dropped the egts significantly
06 lbz cclb all stock
07 gmc lbz ccsb
More aftermarket parts than oem parts
apelineman is offline
post #3 of 18 (permalink) Old 02-02-2011, 05:35 PM
maxcowboy's Avatar
Yeah, a little bit but not more than 1-2MPG. Throttle response did improve though, and that could have a lot to do with it too. Better throttle response means I don't have my foot in it as far, for as long, to get up to speed. And less throttle is used to maintain speed because of a more efficient combustion process, resulting in more power from less fuel. As far as smoke I can't say I noticed any difference, though it doesn't seem to load up and suddenly "blow" a little occasional soot anymore. Just ditching the cat eliminated most of that though. The biggest reason for getting rid of it is to keep from running that soot back through your engine anyway.
Look at it this way...soot it like really fine dust. And we don't want to suck minute amounts of fine dust in the intake. EGR also has very little oxygen, so it has less ability to burn fuel, making more soot. Fine dust, or soot, reduces engine life, period. Even if I don't gain much or anything in fuel economy, I won't, or shouldn't, wear out my engine nearly as fast, so I shouldn't have to buy a new one or rebuild the one I have as soon.
And that my friend, is money in the bank. I may be able to trade it in a year while it's still worth something. I may also not be economically able to do so and need to run it for a million miles. Either way, if I can make it last longer, gain power, run cooler and have less stuff to worry about going wrong while I have it, I'm ditchin the bitch.
05 2500HD, EC, LB. 4" MBRP turbo back, Bully Dog GT, EGR removed, PCV reroute, self customized intake, AFE MP, shimmed FPRV, lift pump and Cat fuel filter conversion, ice picked, head gaskets and bolts at 130,000 Pronghorn flatbed with LOTS of storage and gooseneck ball, RideRite rear bags, front leveled, Lincoln Ranger welder, torch, Puma air comp.
maxcowboy is offline
post #4 of 18 (permalink) Old 02-02-2011, 07:41 PM Thread Starter
Also my truck has the FE9 emission which is just the regular federal emissions. Should my truck's SES light come on with the blocker? I can get the plate for $10 which is pretty cheap.
post #5 of 18 (permalink) Old 02-03-2011, 09:17 AM
2500HD Club Member
maineloggerlbz's Avatar
Some trucks will throw a code if you put the blocker plate in mine did but you can block it with a programmer, the mpg's wont go up much but your motor will be much happier then having the soot run back through the intake etc.
2011 LML ccsb slt- H&S Xrt Pro- 5" flo pro straight pipe- S&B intake
Thanks to alligator performance
maineloggerlbz is offline
post #6 of 18 (permalink) Old 02-03-2011, 09:30 AM
saw what you did there
theunderlord's Avatar
Be sure and do the PCV re-route too!
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #7 of 18 (permalink) Old 02-03-2011, 09:41 AM
2500HD Club Member
How To: PCV Reroute LLY
Heres the link to the DIY PCV re-route or you can buy a kit from a vendor that has all the parts you need
post #8 of 18 (permalink) Old 02-03-2011, 10:11 AM Thread Starter
So I take it that if I do the EGR blocker then it is a must to do the PCV reroute?
post #9 of 18 (permalink) Old 02-03-2011, 10:12 AM
It makes sense. Not a "must", but it's a good idea.
post #10 of 18 (permalink) Old 02-03-2011, 10:36 AM
jkf
jkf's Avatar
Kevin, can you point me to a DIY PCV reroute thread or how-to for LBZ? thanks
2006 GMC Sierra CCLB 2500HD
EFIlive, DSP5, EGR blocked, Magna-flow downpipe, MBRP 5" turbo-back, aFe pro-guard7
Lifetime LED headlights, all on mod, H2 wheels, ride-rite air bags, bed liner,
Truck Cover USA, EBC rotors & pads, tie rods sleeved.
Wants 4049vvt, built tranny
NEEDS: TRAIN HORNS!!!
jkf is offline
