Fass not turning on - Chevy and GMC Duramax Diesel Forum
 2Likes
post #1 of 35 (permalink) Old 01-06-2017, 01:25 PM Thread Starter
Fass not turning on
So I feel like everything that could go wrong in my duramax is going wrong. The other day I noticed when I turned the key that my fass is not coming on??? I checked my fuse and made sure everything is snug. I tried looking it up but everything I saw was for cummins. Please help me out
2006 duramax lbz. 22x12 American forces on 305/40r22 cooper ltz's. Fleece performance 63mm turbo, Fass 150, ATS torque converter with a fully built transmission. Cognito uca with upgraded ball joints and a stage 2 leveling kit, 5" MBRP straight pipe, and DSP-5 from Idaho Rob at ATP trucks
Cokercola88 is offline
post #2 of 35 (permalink) Old 01-06-2017, 08:12 PM Thread Starter
Anyone?
post #3 of 35 (permalink) Old 01-07-2017, 06:02 AM
Don't know much about the Fass but would think it's similar to the Air Dog, mine quit on me a little while back and the fuses were good ended up being the relay was bad. I would check for power at the pump itself and go from there. If you have power at the pump you probably will have to replace the pump itself.
S&B CAI, 4" STAINLESS STEEL EXHAUST, EFI LIVE FROM ATP TRUCKS, EDGE CTS, PPE BOOST VALVE, AIR DOG II 165, REBUILT TRANNY WITH SUNCOAST KIT, TRANSGO SHIFTKIT AND BILLIT TORQUE CONVERTER, NEW UPGRADED TAILSHAFT, PUMP RUB FIX ON TRANSFER WITH NEW ALUMINUM TAIL SHAFT, NEW TOW MIRRORS, NEW GAGE HEAVY DUTY FRONT AND REAR BUMPERS, BEANS SUMP, FUMOTO VALVE, RARE PARTS TIE RODS WITH COGNITO PISK, MAD JACK FUEL FILTER ACCESS DOOR, STAINLESS STEEL SPEED BLEEDERS.
mray is offline
post #4 of 35 (permalink) Old 01-07-2017, 08:38 AM Thread Starter
Do you have a idea where the relay would be?
post #5 of 35 (permalink) Old 01-07-2017, 08:39 AM Thread Starter
I noticed one time it did not come on so I turned the key off and turned the key again and it came on
post #6 of 35 (permalink) Old 01-07-2017, 08:45 AM
DirtEmax-USMC's Avatar
Free bump Not sure about whats going on
2015.5 2500 CC/SB, PCV Reroute, Res. Delete, Nitto Ridge Grap. 275/70/16, XD misfit Wheels (FOR SALE), S&B Intake, MotorOps tunes via Meyers Performance. FASS 150, Beans Sump, Blocker Plates
Coming soon/Plans:
Down pipe, 4'' Exhaust, EGR Delete, Intercooler, intercooler pipes, PPE pipes, SDP trans
SHEEPDOG
Til-Valhalla
The Dysfunctional Veteran
DirtEmax-USMC is offline
post #7 of 35 (permalink) Old 01-07-2017, 11:19 AM
The relay should be on the wire harness that was supplied with the pump, it's a square gray or black box that's about an inch square.
mray is offline
post #8 of 35 (permalink) Old 01-07-2017, 04:57 PM Thread Starter
Does it sound like a relay since once before it didn't come on and then after I turned the key again it came on? Or is is sounding like a pump
post #9 of 35 (permalink) Old 01-08-2017, 05:47 AM
Could be either one. I would check the voltage at the pump with a volt meter to determine if it's getting power there.
mray is offline
post #10 of 35 (permalink) Old 01-08-2017, 06:21 AM
Good deal on Amazon if your interested. Just picked one up myself.
mray likes this.
Coming soon/Plans:
SHEEPDOG
Til-Valhalla
