Leaking transmission lines - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 07-27-2011, 09:28 PM Thread Starter
Does the dealer replace your transmission fluid when they replace the leaking transmission lines? Is the replacement lines a permenant fix? Or do they use the same type which will start leaking again?
2007.5 GMC Sierra 2500 6.6 duramax with Allison tran.
Duramax007 is offline
post #2 of 10 (permalink) Old 07-27-2011, 10:56 PM
Tow Master's Avatar
The dealer will just top it off when they do it. Also, the dealer puts the same type of line that came on the truck when you bought it. You can buy a better line but there pricey.
If the dealers gonna do it under warranty then Id just go there.
Jason
Tow Master is offline
post #3 of 10 (permalink) Old 07-27-2011, 11:03 PM
Banned
No, No, and Yes.
Hondarider552 is offline
post #4 of 10 (permalink) Old 07-27-2011, 11:38 PM
Mine started leaking shortly after I bought it, they were not covered under warranty. I did get to see the old lines and the new ones they put on look to have a better design to them.
I think they ran me around $250ish
08 GMC Sierra 2500 Z71 4x4 CCSB SLT - Black Exterior - Tan Interior - Banks Ram Air Intake - Banks Dual Exhaust
prime81 is offline
post #5 of 10 (permalink) Old 07-28-2011, 02:25 AM
I think it sucks that everyone has problems with these damn tranny lines. Mine crapped out at 65k and the stealership charged me $450...I know it can be done for less but I don't have time to dink around with fixing my truck. I wish they would get that squared away!
07' LBZ Crew Cab
MakinPower is offline
post #6 of 10 (permalink) Old 07-28-2011, 02:59 AM
Street Sleeper
Headless_Horseman's Avatar
Send a message via AIM to Headless_Horseman
Just go and have some hydraulic lines made and crimped to the specs needed to hook up to the Allison. Alligator Performance and Husker Diesel both sell upgrade kits that are a permanent fix with good fittings on them to solve the problem. I crapped out with less than 40k on the truck, I just had a set made and installed by DTS from Goodyear high pressure hydrualic lines. Larger internal diameter with a bit more flow, problem solved!
2007.5 GMC Sierra 2500HD SLT LMM CCSB 4x4
Banks CAI w/Scoop - Banks Intercooler
Hot/Cold IC pipes - Custom Y Bridge
EGR delete - Danville 68MMSTG2R
PPE Up-pipes & Manifolds - Diamond Eye DP
5" TB Flo-Pro - ADII
DT EFI Live w/ DSP5 - Built DTS Trans
S4 Shocker Train Horns
Go DAWGS!!!
Headless_Horseman is offline
post #7 of 10 (permalink) Old 07-28-2011, 05:26 PM
KB3MMX's Avatar
Exclamation
Get rid of the DEX VI as quick as you can and replace it with Allison Transynd fluid or Amsoil Torque Drive.
Dex6 is the major cause of all the damn trans line leaks.
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD
--CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive by KB3MMX Tuning W/ SDP Towing Twins (Billet S475 over Stock)
--SILVERLINE 4" Stainless Exhaust
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
--Airdog II DF200 w/ CAT UHE filter upgrade...etc,etc...
KB3MMX is offline
post #8 of 10 (permalink) Old 07-28-2011, 10:38 PM
Tow Master's Avatar
1. He never said he had Dex6.
2. I never heard of that before.
Jason
post #9 of 10 (permalink) Old 07-28-2011, 10:41 PM
I'm That Guy...
TDFDiesel's Avatar
Originally Posted by Hondarider552 View Post
No, No, and Yes.
Does it have to be in that order?
Tony
Old Trucks: 3 - LLY, 1 - LMM
TDFDiesel is offline
post #10 of 10 (permalink) Old 07-28-2011, 11:23 PM
Banned
Dex 6 isnt the reason why the lines leak, the crimp is. I have Transynd in my LBZ and the lines leaked..
Yes.
