DPF Delete without tuner. - Page 6 - Chevy and GMC Duramax Diesel Forum
post #51 of 59 (permalink) Old 11-07-2011, 06:06 AM
poosniffer's Avatar
Originally Posted by smokinlmm View Post
Yes, you can see how much is left just call the warraty office where you bought it and ask them.
if I can get $$$ on unused warranty,it would kinda be like getting paid to delete the DPF.
2008 LMM Silverado 2500 LTZ ECSB 4X4.
Aftermarket DSP5 calibration by Danville Performance, Blocked and re-routed, Nicktane with Baldwin BF7587, PPE lift pump with Baldwin BF1212 water separator, 285/75/17 Dura Grapplers on H2s, CTS Insight with pyro.HIDs in fogs and high beams.
Proud Member U/A Local 693 Plumbers/Pipefitters.
poosniffer is offline
post #52 of 59 (permalink) Old 11-07-2011, 07:32 AM
bowtie06's Avatar
You can always sell it and buy an early 07....and not have to worry about that bs...welcome to the forum
- Rick
06' LBZ CC SB Duramax Blck 4x4
Leveled,V2 and DSP 5 from ROB ,
straightpiped MBRP 4"
Nitto Terra Grapps
285/70/R17's on Eagle Alloy Super Finish Black
B&W Turnover,
NBS Smoke Recons
atptrucks.com
bowtie06 is offline
post #53 of 59 (permalink) Old 11-08-2011, 03:20 PM
MRBASS's Avatar
Actually the gm warranty is transferable. I just transfered one 2weeks ago. You will have to call and see if you can cancel and get a prorated refund. Depends on the type of plan.
You can also buy a dpf-r module and delete the dpf without any tuner. I know nothing about it but have seen them advertised and know 2 people who use them, 1 on a ford and another on an lmm. The lmm has been running 45k with the module and no issues.
Might do some research on that..
2010 3500HD SRW CCLB LTZ LMM
STOCK? NOT SO MUCH..
MRBASS is offline
post #54 of 59 (permalink) Old 11-08-2011, 03:27 PM
blackdeath's Avatar
u are correct but still will void his warranty , flopro sells one , id give the part number but im not sure im aloud
blackdeath is offline
post #55 of 59 (permalink) Old 05-16-2012, 01:51 AM
DPF delete help!!
well i have my truck and my dealer said not to worry about the warranty if i put a tuner on it. my question is where to start. I have the AFE system and want to replace it from the cat back deleting the DPF and muffler.
what tuner is this i hear so much about that will turn my check engine light off and prevent damage to the engine from repeated regen cycles?
do i need to reinstall the sensors and pressure line?
mostly will just installing the pipes without running it damage the engine, turbo ect?
thanks for any help guys
2007 LMM 6.6 duramax 2500HD
dholifield is offline
post #56 of 59 (permalink) Old 01-01-2014, 09:35 AM
i no i need a delete kit but i put full delete pipe and all sensors back on to pipe and its saying poor def fluid will not reset change all the def and still saying power reduced can anybody no what i need todo other than buying the full delete
hunt duramax is offline
post #57 of 59 (permalink) Old 01-02-2014, 06:26 PM
Heavy Duty's Avatar
Check the search function on DPF Delete LMM, and for Tuners. I would suggest EFI LIVE. Several excellent vendors advertise here who could provide you some assistance. Welcome to the forum!
2007.5 Chevy HD2500 Z71 LT2 LMM Duramax
B&W Turnover Ball Gooseneck Hitch
Weathertech Floormats
Dashmat Ultimat
T-Bars Cranked Just To Level
1st Diesel ~ Bone Stock.
Must do some upgrades.
Heavy Duty is offline
post #58 of 59 (permalink) Old 01-02-2014, 06:30 PM
Heavy Duty's Avatar
Welcome to the forum! A little more info on your truck would help answering your question. I assume since you mention DEF FLUID you have a newer Duramax. I'm not too familiar with the newer rigs, and I've heard they are working on the tuners for the newer models. As with some of the older rigs, I'm sure if you delete anything, you will need a Tuner such as EFI LIVE. I'm sure you will get some other responses from those more familiar with the newer Max's.
Dashmat Ultimat
post #59 of 59 (permalink) Old 01-02-2014, 08:41 PM
D_R_C's Avatar
It's better to NOT put the sensors back on that confuses the emissions system.
If you have the DPF delete pipe with bungs for the sensors then plug them.
You do have a tuner programmed in that cancels emissions codes don't you?
If not then I suggest you work on that.
You will NOT by-pass these issues by just using the DPF delete pipe and install the sensors, get a tuner.
Also this section is for 2007.5 - 2010 LMM WITH NO DEF SYSTEM.
2007.5 GMC Sierra 3500 SRW "BLACK", SLT, C.C., 4X4, Loaded, DMax,Z71
Edge Insight CTS2, CFM Billet Valve Cover/Oil Fill Neck Breather, PCV Re-Route, Sinister EGR Delete, AirDog, ISSPRO fuel pressure gauge, BD Manifold, Diamond Eye down pipe & front pipe, 5" DPF(less)back exhaust with 6" tip, DIY Stock airbox mod with aFe Proguard 7 airfilter, Cognito NON Torsion Bar 4" lift, Cognito UCA's, Pitman/Idler arm support, Sulastic Rubber Shackles, Firestone Ride Rite, Bilsteins 5100's front/rear
EFILive ECM tuned by ATP www.atptrucks.com
TCM
tuned by www.duramaxtuner.com
DIY stock AirBox Mod, K&N, Airaid intake, EFILive TCM only by MJE Tuning
D_R_C is offline
