LMM DPF Delete - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 06-09-2012, 11:42 PM Thread Starter
LMM DPF Delete
Those of you that delete the DPF; Do you put it back on when you have to smog your truck, and retune for stock? And then delete the DPF again and install your tune and have fun until the smog test is due again? Or are most of you in areas that do not require smog tests?
2008 GMC 3500 SLT Dually 4X4
Dually Club Member #104
Edge Evolution CTS
235/80-17 Toyo AT2
dakster1a is offline
post #2 of 12 (permalink) Old 06-10-2012, 12:29 AM Thread Starter
8 views and no replies? I am not the DPF police! Haha
Edge Evolution CTS
235/80-17 Toyo AT2
post #3 of 12 (permalink) Old 06-10-2012, 12:33 AM
Jhill's Avatar
I am in a county that does not require exhaust testing. The next county over, where Boise is located does. I know a couple Dodge/Ford guys that throw it on for test and take it off to sit in the garage for another 12 months.
2008 2500HD CCSB
EFI Live by Idaho Rob Coddens Adrenaline Truck Performance
Rare Parts tie rods from Alligator Performance
4" turbo back MBRP by Pat at BT Diesel
lifted with 35s.
Originally Posted by oleblack03
Every time I hear someone say that their half-ton will tow as much as my 3/4 ton I just compare it to having sex with your cousin.......it can get the job done.....but the longterm effects can really F%$ something up
Originally Posted by ty_LBZ View Post
A firefighter inherits a bad situation too, but you don't see him throwing gas on the fire...
Jhill is offline
post #4 of 12 (permalink) Old 06-10-2012, 12:39 AM Thread Starter
Thanks J. I was thinking that would be the way to go.
Edge Evolution CTS
235/80-17 Toyo AT2
post #5 of 12 (permalink) Old 06-10-2012, 09:25 PM
"THEEPASUCKS"
WOLFN8TR's Avatar
Yep basically something like that....
2008 2500HD LTZ
EFI LIVE DSP5 - Edge CTS Insight - Transgo Jr.
6" Superlift - 35" Trail Grapp's - 18"Mazzi Hulks
Amp Research Steps - Billet Grille - PCV Reroute - DE Down Pipe - MBRP SS Exhaust - AFE Delete Pipe
Cognito Braces - Fabtech HD Tierods - PPE Deep Pan
Dmaxstore - Duramaxtuner - Madjacksracing -
MeyerPerformance - Alligatorperformance - Performancetruckproducts
WOLFN8TR is offline
post #6 of 12 (permalink) Old 06-11-2012, 04:47 PM Thread Starter
Thanks Wolf. Sounds like a plan.
Edge Evolution CTS
235/80-17 Toyo AT2
post #7 of 12 (permalink) Old 06-11-2012, 06:03 PM
"THEEPASUCKS"
WOLFN8TR's Avatar
Sure no problem. Read my sig, that's the route I went.
2008 2500HD LTZ
WOLFN8TR is offline
post #8 of 12 (permalink) Old 06-14-2012, 03:09 AM
Brandon2008LMM's Avatar
U can always gut your dpf, like where I live if the emission stuff doesn't look like its been messed with they won't check it.
2002 LB7 LT CC/SB MODS CHANGING SO I WILL UPDATE LATER
2008 LMM LTZ CC/SB 4" SS Magna-flo turbo back with 6" tip, Stock air box modd, fass fuel titanium 95, EFI Live by timmy at st joe diesel, 18" Helo wheels wrapped with 285/65/18 Nitto Terra Grapplers, horse power to be determined, SOLD
1998 Chevy Camaro Z28, not stock
Brandon2008LMM is offline
post #9 of 12 (permalink) Old 06-14-2012, 04:46 PM Thread Starter
I like that idea. Thanks!
Edge Evolution CTS
235/80-17 Toyo AT2
post #10 of 12 (permalink) Old 06-15-2012, 11:47 PM Thread Starter
One more question guys: If I were to either gut the inside of the dpf or delete it and disguise the straight pipe so that I can fool the smog dude, will the truck actually pass the test without it?
Edge Evolution CTS
235/80-17 Toyo AT2
