Reduced engine power - Chevy and GMC Duramax Diesel Forum
post #1 of 109 (permalink) Old 06-27-2012, 01:04 AM Thread Starter
Question Reduced engine power
Hello, I have a 2008 Gmc Sierra 2500HD Duramax Diesel with about 55,000 miles on it. It keeps getting a "reduced engine power" message on the dash, then it doesn't have any power, its like putting a brick under the gas pedal.
I have went to the dealer and they cleared the code so they could try to duplicate the code, which it never came back for them. I use to have edge juice with attitude hooked up to it, so the dealer says thats what is screwing up my truck. Even when it isn't hooked up I will still get the "reduced engine power" message. I really hope someone here knows whats wrong with the truck, please help. Thank you
toohott7718 is offline
post #2 of 109 (permalink) Old 07-02-2012, 04:19 AM
If you have that programmer chose the setting of return back to stock, don't load any programming on it and then scan for DTCs.
Dan1969 is offline
post #3 of 109 (permalink) Old 07-02-2012, 08:09 AM
polarisiq93's Avatar
You should find out what code it is throwing first. Could be as simple as an oxygen sensor. I kept getting p0101 which is maf sensor. I highly doubt it's your programmer that's making the codes. Stupid stealerships
Sent from my iPhone 4s
07.5 LMM ccsb ltz MATTE BLACK
8 inch fabtech lift,36x15.50 baja mtz's,20x12 fuel nutz,reflexxion hood,rbp grille,s&b cai,recon smoked headlights,dsp5 by Kory Willis,mbrp 5 inch TB,mbrp dp,7" black chrome stack,PPE boost and pyro gauges,edge insight cts,bd blow off,egr delete,pcv re-route, alpine touch screen, 2 10" type r's SOLD
new truck- 2011 Denali lml, 6 inch fabtech lift, 22x12 american force rebel's, 35" terra grapplers, h&s mini max, banks cai, 5" exhaust, rigid 20", recon tails and 3rd brake light
polarisiq93 is offline
post #4 of 109 (permalink) Old 07-02-2012, 09:19 AM
D_R_C's Avatar
^^^what he said^^^
You need to find out what the trouble code is first before the problem can be addressed.
If your dealer was not smart enough to do this, then find someone else that is.
2007.5 GMC Sierra 3500 SRW "BLACK", SLT, C.C., 4X4, Loaded, DMax,Z71
Edge Insight CTS2, CFM Billet Valve Cover/Oil Fill Neck Breather, PCV Re-Route, Sinister EGR Delete, AirDog, ISSPRO fuel pressure gauge, BD Manifold, Diamond Eye down pipe & front pipe, 5" DPF(less)back exhaust with 6" tip, DIY Stock airbox mod with aFe Proguard 7 airfilter, Cognito NON Torsion Bar 4" lift, Cognito UCA's, Pitman/Idler arm support, Sulastic Rubber Shackles, Firestone Ride Rite, Bilsteins 5100's front/rear
EFILive ECM tuned by ATP www.atptrucks.com
TCM
tuned by www.duramaxtuner.com
DIY stock AirBox Mod, K&N, Airaid intake, EFILive TCM only by MJE Tuning
D_R_C is offline
post #5 of 109 (permalink) Old 07-03-2012, 11:26 PM
DuraMAXX7's Avatar
I have this exact same problem. Happened to me again tonight for the second time. Within a couple hours, my programmer gets rid of the code, but i'll have checked out anyways to make sure its nothing serious.
2016 White High Country Duramax
PPEI ECM and TCM Tunes
5" Flo Pro, Fass 150 and Beans Sump
Edge Insight CTS2
TRS 5000K HID's, TRS Fog Lights
Cognito 4-6", 325/55r22 Nitto Trail Grapplers, 22x12 Fuel Forged FF19
SOLD: 2011 Chevy 2500HD LML Black
SOLD: 2008 Duramax with lots of go fast parts
DuraMAXX7 is offline
post #6 of 109 (permalink) Old 07-04-2012, 02:22 AM Thread Starter
I went back to the shop today and the dealer tried to charge me another $100.00 deductable for the repair, it was the same exact problem I had a little over a week ago. I told the service rep there was no way I'm paying again for something they were suppose to fix the last time I was there. He finally said I'll waive this deductable but I won't do any more repairs that have to do with driveability issues, what a bunch of sh*t. Anyway they said my gas pedal needed to be replaced, I looked at the invoice when I got in my truck and along with the gas pedal in the description it said throttle position sensor. I'm not sure if it is apart of the gas pedal or not but I do believe it was the TPS.
post #7 of 109 (permalink) Old 07-05-2012, 10:50 PM Thread Starter
Let me know what the dealer says about your truck, I'm curious to know if it is the same thing as my truck, good luck!!
post #8 of 109 (permalink) Old 07-06-2012, 06:09 PM
srud's Avatar
I am curious about your situation. Are there any unique circumstances associated with the reduced power? I.E. towing, weather (temps), anything else you can think of?
I ask because mine is doing the same thing after towing my boat and then sitting for 15 to 20 mins. I can get the boat to the lake but can't get it home.
2008 2500HD Crew Cab - Stock
srud is offline
post #9 of 109 (permalink) Old 07-06-2012, 06:39 PM
D_R_C's Avatar
Guys get yourselves a code checker/clearer then YOU will know what the problem might be, instead of having to be depending on the dealer.
Mac tools has 2 great little scanners $79-$99
TCM
D_R_C is offline
post #10 of 109 (permalink) Old 07-07-2012, 08:35 PM
I've found 3 things that cause "reduced engine power":
1. Air Filter
2. Fuel Filter
3. Bad accelerator position sensor.
I have put 2 new accelerators in my truck in 77,000 miles.
2008 Silverado 3500HD
toddelof is offline
